AXIS Q3505-V is a high-performance, vandal-resistant fixed dome for high-security applications indoors. The camera is available with wide or telephoto lens. The camera delivers HDTV 1080p video at up to 60 frames per second, providing smooth video even when capturing fast movements.
The camera's Wide Dynamic Range (WDR) – Forensic Capture capability provides perfectly balanced video quality in scenes with strong variations in light, while the Lightfinder technology enables outstanding image usability in poor light. The camera can seamlessly transition between handling WDR and low-light conditions. AXIS Q3505-V also supports Axis’ Electronic Image Stabilization (EIS), which greatly improves video quality in situations where the camera is subject to vibration.
Furthermore, the camera supports barrel distortion correction and includes optical zoom that can be used when monitoring a scene. When using the optical zoom for monitoring, an operator can zoom in on an object, or the camera can zoom in automatically when the Gatekeeper functionality is applied.
Top-of-the-line image usability
AXIS Q3505-V is a high-performance, vandal-resistant fixed dome for high-security applications indoors. The camera is available with wide or telephoto lens. The camera delivers HDTV 1080p video at up to 60 frames per second, providing smooth video even when capturing fast movements. The camera's Wide Dynamic Range (WDR) - Forensic Capture capability provides perfectly balanced video quality in scenes with strong variations in light, while the Lightfinder technology enables outstanding image usability in poor light. The camera can seamlessly transition between handling WDR and low-light conditions. AXIS Q3505-V also supports Axis' Electronic Image Stabilization (EIS), which greatly improves video quality in situations where the camera is subject to vibration. Furthermore, the camera supports barrel distortion correction and includes optical zoom that can be used when monitoring a scene. When using the optical zoom for monitoring, an operator can zoom in on an object, or the camera can zoom in automatically when the Gatekeeper functionality is applied. -
Efficient, reliable and versatile installation
AXIS Q3505-V is designed for reliable and vandal-resistant installation. It has IK10 impact resistance and IP52-rated dust and water protection. If the camera is hit, the shock detection capability can send an alarm to alert an operator. The camera's versatile cable management features service loop space and optional connection to any type of conduit. The remote zoom and focus capability provides convenient zooming and focusing over the network, eliminating the need for hands-on fine-tuning. The camera's leveling assistant and autorotation aids are useful at installation to ensure horizontally aligned and correctly rotated images wherever or however the cameras are mounted. AXIS Q3505-V is ideal for high-security applications in areas such airports, railway stations, and industrial and critical infrastructure facilities.
- AXIS Q3505-V Network Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome - dustproof / waterproof / vandal-proof
- Audio
- Yes: two-way audio capability
- 16.2 cm x 16.2 cm x 11.6 cm
- 1.2 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 2.4 x
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 60 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/2.8" - 2.3 MP
- Minimum Illumination
- 0.56 lux - colour - F1.6 , 0.11 lux - B&W - F1.6
- Focal Length Control
- Vari-focal
- Focal Length
- 9 mm - 22 mm
- Lens Iris
- F/1.6 - auto iris (P-Iris)
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Backlight Compensation (BLC), manual exposure, sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, contrast control, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), infrared cut filter, Privacy Mask Function, Electronic Image Stabilizer (EIS), text stamp, Video Motion Detection Technology, Lightfinder technology, active tampering alarm, digital PTZ function, ONVIF V2.2 (Profile S) support, password protection, microSD/SDHC/SDXC Memory Card slot, shock detection, Audio Detection
- 3-year warranty
- Environmental Parameters (operating)
- -10 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
- Audio Support
- Form Factor
- Dome
- Wired
- 16.2 cm
- 16.2 cm
- 11.6 cm
- 1.2 kg
Camera
- Colour - Day&Night - fixed - dustproof / waterproof / vandal-proof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Digital Zoom
- 2
- Exposure Range
- 2 sec - 1/142850 sec
- Video Capture
- 1920 x 1080 @ 60 fps
- RAM
- 512 MB
- Flash Memory
- 128 MB
Image Sensor
- 2.3 MP CMOS 1/2.8"
Lens Construction
- Vari-focal
- Optical Zoom
- 2.4 x
- Focal Length
- 9 mm - 22 mm
- Lens Iris
- F/1.6 auto iris (P-Iris)
- Horizontal Field of View (degree)
- 16 - 33
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS
- Ports
- LAN/power - RJ-45 , Audio line-in/microphone - 3.5 mm jack , Audio line out - 3.5 mm jack
- C-Tick, CISPR 22 Class B, EN55024, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60068-2-27, IEC 60068-2-6, IEC 60529 IP52, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, AS/NZS, IEC 60068-2-52, IEC 62262 IK10, IEC 60068-2-60, EN 50121-4, IEC 62236-4, VCCI Class B, KN24, IEC 61000-6-1:2005, IEC 61000-6-2:2005, KCC KN22 Class B
- Power Requirements
- PoE
- Power Device
- 5.5 Watt
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- -10 °C
- 50 °C
- Relative Humidity (operating)
- 10 - 85% (non-condensing)
