The AXIS M3027-PVE network camera is a 5-megapixel fixed mini dome that provides detailed, high quality 360° or 180° panoramic views. The vandal resistant, outdoor-ready mini dome can be used to detect activities, track the flow of people and improve area management. The camera is ideal for installations indoors or outdoors at hotels, gas stations, boutiques, restaurants, schools and offices.
AXIS M3027-PVE offers different views: 360° overview and dewarped views such as panorama, double panorama and quad views. The quad view is suitable, for instance, when the camera is positioned at an intersection. The camera also provides four individually cropped out and dewarped view areas where users can digitally pan, tilt and zoom in on areas of interest. Multiple video streams in H.264 and Motion JPEG can be sent simultaneously.
360° or 180° panoramic surveillance
The AXIS M3027-PVE network camera is a 5-megapixel fixed mini dome that provides detailed, high quality 360° or 180° panoramic views. The vandal resistant, outdoor-ready mini dome can be used to detect activities, track the flow of people and improve area management. The camera is ideal for installations indoors or outdoors at hotels, gas stations, boutiques, restaurants, schools and offices. -
Different views
AXIS M3027-PVE offers different views: 360° overview and dewarped views such as panorama, double panorama and quad views. The quad view is suitable, for instance, when the camera is positioned at an intersection. The camera also provides four individually cropped out and dewarped view areas where users can digitally pan, tilt and zoom in on areas of interest. Multiple video streams in H.264 and Motion JPEG can be sent simultaneously. -
Outdoor-ready, day and night
The mini dome is outdoor-ready and vandal-resistant, with IP66, NEMA 4X and IK10 ratings. It has day/night functionality with an automatically removable infrared-cut filter. When the filter is removed, the camera takes advantage of invisible near-infrared light from available light sources to produce good quality black and white video. -
Easy and flexible installation
AXIS M3027-PVE can be mounted on a wall or ceiling. The camera comes focused at delivery, which shortens the installation time. It supports Power over Ethernet (IEEE 802.3af), which eliminates the need for power cables and reduces installation costs.
- AXIS M3027-PVE Network Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome - outdoor - vandal / weatherproof
- 13.2 cm x 13.2 cm x 7.3 cm
- 740 g
- White
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Motion Detection
- Optical Sensor Type
- CMOS - 1/3.2"
- Minimum Illumination
- 0.3 lux - colour - F2.0 , 0.06 lux - B&W - F2.0
- Focal Length
- 2.8 mm
- Lens Mounting
- M12 mount
- Lens Iris
- F/2.0 - fixed iris
- Ethernet 10Base-T/100Base-TX
- Voltage
- High PoE
- Backlight Compensation (BLC), manual exposure, sharpness control, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, image mirror, Wide Dynamic Range (WDR), ONVIF support, Privacy Mask Function, text stamp, Video Motion Detection Technology, tamper-detection, digital PTZ function, SDXC-card slot
- 1-year warranty
- Environmental Parameters (operating)
- -30 °C - 50 °C; 10 - 100% relative humidity
- Form Factor
- Dome
- Wired
- 13.2 cm
- 13.2 cm
- 7.3 cm
- 740 g
Camera
- Colour - Day&Night - fixed - outdoor - vandal / weatherproof
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Exposure Range
- 2 sec - 1/24000 sec
- RAM
- 512 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/3.2"
Lens Construction
- M12 mount
- Focal Length
- 2.8 mm
- Lens Iris
- F/2.0 fixed iris
- Horizontal Field of View (degree)
- 187 - 180
- Vertical Field of View (degree)
- 180
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
- Alarm Inputs Qty
- 1
- Alarm Outputs Qty
- 1
- Supported Memory Cards
- SDXC Memory Card
- CISPR 22 Class B, EN55024, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, NEMA Type 4X, EN 61000-6-2, FCC CFR47 Part 15 B, IEC 62262 IK10, VCCI Class B, KN22, KN24
- White
- Power Requirements
- High PoE
- Power Device
- 4.5 Watt
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year
- -30 °C
- 50 °C
- Relative Humidity (operating)
- 10 - 100%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
