Product
Axis M3027-PVE Network CCTV Camera
Quicklinx: B93JWS00 Mfr#: 0556-001
The AXIS M3027-PVE network camera is a 5-megapixel fixed mini dome that provides detailed, high quality 360° or 180° panoramic views. The vandal resistant, outdoor-ready mini dome can be used to detect activities, track the flow of people and improve area management. The camera is ideal for installations indoors or outdoors at hotels, gas stations, boutiques, restaurants, schools and offices.
AXIS M3027-PVE offers different views: 360° overview and dewarped views such as panorama, double panorama and quad views. The quad view is suitable, for instance, when the camera is positioned at an intersection. The camera also provides four individually cropped out and dewarped view areas where users can digitally pan, tilt and zoom in on areas of interest. Multiple video streams in H.264 and Motion JPEG can be sent simultaneously.
  • 360° or 180° panoramic surveillance
  • Different views
  • Outdoor-ready, day and night
    The mini dome is outdoor-ready and vandal-resistant, with IP66, NEMA 4X and IK10 ratings. It has day/night functionality with an automatically removable infrared-cut filter. When the filter is removed, the camera takes advantage of invisible near-infrared light from available light sources to produce good quality black and white video.
  • Easy and flexible installation
    AXIS M3027-PVE can be mounted on a wall or ceiling. The camera comes focused at delivery, which shortens the installation time. It supports Power over Ethernet (IEEE 802.3af), which eliminates the need for power cables and reduces installation costs.
AXIS M3027-PVE Network Camera - network surveillance camera
Network surveillance camera - fixed dome - outdoor - vandal / weatherproof
13.2 cm x 13.2 cm x 7.3 cm
740 g
White
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Motion Detection
Optical Sensor Type
CMOS - 1/3.2"
Minimum Illumination
0.3 lux - colour - F2.0 , 0.06 lux - B&W - F2.0
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0 - fixed iris
Ethernet 10Base-T/100Base-TX
Voltage
High PoE
Backlight compensation, manual exposure, sharpness control, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, image mirror, Wide Dynamic Range (WDR), ONVIF support, Privacy Mask Function, text stamp, Video Motion Detection Technology, tamper-detection, digital PTZ function, SDXC-card slot
1 year warranty
Environmental Parameters (operating)
-30 °C - 50 °C; 10 - 100% relative humidity
Wired
13.2 cm
13.2 cm
7.3 cm
740 g
Camera
Colour - Day&Night - fixed dome - outdoor - vandal / weatherproof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Exposure Range
2 sec - 1/24000 sec
RAM
512 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/3.2"
Lens Construction
M12 mount
Focal Length
2.8 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
187 - 180
Vertical Field of View (degree)
180
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
Supported Memory Cards
SDXC Memory Card
CISPR 22 Class B, EN55024, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, NEMA Type 4X, EN 61000-6-2, FCC CFR47 Part 15 B, IEC 62262 IK10, VCCI Class B, KN22, KN24
White
Power Requirements
High PoE
4.5 Watt
Software Included
Drivers & Utilities
Limited warranty - 1 year
-30 °C
50 °C
Relative Humidity (operating)
10 - 100%
B93J C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.17
B93J C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.27
B93J C2G 2m Cat6a Shielded Patch - Blue In Stock £6.93
B93J C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £44.73
