AXIS M3025-VE network camera, which is part of the AXIS M30 series, is an affordably priced, vandal-resistant HDTV fixed mini dome for excellent video during day and night-time conditions in indoor or outdoor environments. It is ideal for installation inside or outside the entrance of a hotel, boutique, restaurant, office or school.
AXIS M3025-VE provides 2-megapixel, HDTV 1080p video. The outdoor-ready camera has IP66 and NEMA 4x ratings for protection against dust, rain and snow. The camera's IK 10 rating ensures resistance against impacts.
It also has day/night functionality with an automatically removable infrared-cut filter. When the filter is removed, the camera takes advantage of invisible near-infrared light from available light sources to produce good quality black and white images.
Outdoor-ready, day and night
AXIS M3025-VE network camera, which is part of the AXIS M30 series, is an affordably priced, vandal-resistant HDTV fixed mini dome for excellent video during day and night-time conditions in indoor or outdoor environments. It is ideal for installation inside or outside the entrance of a hotel, boutique, restaurant, office or school. AXIS M3025-VE provides 2-megapixel, HDTV 1080p video. The outdoor-ready camera has IP66 and NEMA 4x ratings for protection against dust, rain and snow. The camera's IK 10 rating ensures resistance against impacts. It also has day/night functionality with an automatically removable infrared-cut filter. When the filter is removed, the camera takes advantage of invisible near-infrared light from available light sources to produce good quality black and white images. -
Easy to install
The fixed dome can be mounted on walls, ceilings or pendants. It has a 3-axis camera angle adjustment for flexible installation. The camera also supports Axis' corridor format for vertically oriented video streams that maximize coverage of areas such as along walls or aisles. The camera comes focused at delivery. AXIS M3025-VE has input/output ports for connection to external devices. It also supports AXIS camera application platform for intelligent video applications. The camera offers a convenient video management solution with its built-in memory card slot for edge storage and support for software such as the complimentary AXIS camera companion.
- AXIS M3025-VE Network Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome - outdoor - vandal / weatherproof
- 13.2 cm x 13.2 cm x 9.3 cm
- 740 g
- White
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/2.7" - 2 MP
- Minimum Illumination
- 0.8 lux - colour - F2.0 , 0.16 lux - B&W - F2.0
- Focal Length Control
- Fixed focal
- Focal Length
- 3.6 mm
- Lens Mounting
- M12 mount
- Lens Iris
- F/2.0 - fixed iris
- Panning Range (degree)
- -175 to +175
- Tilting Range (degree)
- 70
- Ethernet 10Base-T/100Base-TX
- Cables Included
- 1 - network cable - 2 m
- Voltage
- PoE Class 2
- Backlight Compensation (BLC), sharpness control, white balance, progressive scanning, contrast control, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), infrared cut filter, Privacy Mask Function, text stamp, Video Motion Detection Technology, active tampering alarm, digital PTZ function, ONVIF V2.2 (Profile S) support, password protection
- 1-year warranty
- Environmental Parameters (operating)
- -30 °C - 50 °C; 10 - 100% relative humidity
- Form Factor
- Dome
- Wired
- 13.2 cm
- 13.2 cm
- 9.3 cm
- 740 g
Camera
- Colour - Day&Night - fixed - outdoor - vandal / weatherproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Exposure Range
- 1/6 sec - 1/8000 sec
- Frame Rate (max)
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- 2 MP CMOS 1/2.7"
Lens Construction
- M12 mount - fixed focal
- Focal Length
- 3.6 mm
- Lens Iris
- F/2.0 fixed iris
- Horizontal Field of View (degree)
- 91
Panning
- Range (degree)
- -175 to +175
Tilting
- Range (degree)
- 70
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
- Alarm Inputs Qty
- 1
- Alarm Outputs Qty
- 1
- Ports
- LAN/power - RJ-45
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Cables Included
- 1 x network cable - 2 m
- C-Tick, EN55024, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, NEMA Type 4X, EN 61000-6-2, IEC 62262 IK10, VCCI Class B, EN 50581, KN24, IEC 60950-22, EN 60950-22, UL 60950-22, KCC KN22 Class B, AS/NZS CISPR 22 Class B
- White
- Power Requirements
- PoE Class 2
- Power Device
- 3.2 Watt
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year
- -30 °C
- 50 °C
- Relative Humidity (operating)
- 10 - 100%
