AXIS M3006-V Network Camera delivers superb 3-megapixel video with a wide-angle view, and supports full frame rate HDTV 1080p. The affordably priced camera offers a cost-effective solution for retail stores, hotels, schools and offices with tight budgets for video surveillance.
Click on image to enlarge AXIS M3006-V provides a viewing angle of 134°, while its 3-megapixel resolution provides 50% more details than HDTV 1080p. With its wide horizontal and vertical angles of view, as well as its high resolution, the camera can offer complete coverage when installed near a corner of a store. A corner installation would also enable users to look into the shelves on either side of the camera.
Ideal for tight video surveillance budgets
AXIS M3006-V Network Camera delivers superb 3-megapixel video with a wide-angle view, and supports full frame rate HDTV 1080p. The affordably priced camera offers a cost-effective solution for retail stores, hotels, schools and offices with tight budgets for video surveillance. -
Perfect for corner views
Click on image to enlarge AXIS M3006-V provides a viewing angle of 134°, while its 3-megapixel resolution provides 50% more details than HDTV 1080p. With its wide horizontal and vertical angles of view, as well as its high resolution, the camera can offer complete coverage when installed near a corner of a store. A corner installation would also enable users to look into the shelves on either side of the camera. -
Quick and flexible installation
The vandal- and dust-resistant indoor mini dome enables easy and discreet installation. With a 3-axis camera angle adjustment, the camera can be mounted on walls or ceilings. The direction of the camera can be easily adjusted and the image leveled. The camera supports Axis' corridor format, which enables vertically oriented video streams that optimize coverage of areas such as corridors, hallways or store aisles. -
Digital PTZ and multi-view streaming
AXIS M3006-V supports digital pan/tilt/zoom, which can be used as a "digital varifocal lens" that allows the angle of view to be adjusted remotely after the physical installation. The camera's digital PTZ, together with its support for multi-view streaming, enables different areas of a scene to be cropped from the full view and streamed simultaneously for viewing or recording - simulating several virtual cameras that can help minimize the bit rate and storage needs. Multiple streams in H.264 and motion JPEG can be sent simultaneously. -
Intelligent video capabilities
AXIS M3006-V includes intelligent capabilities such as video motion detection and detection of camera tampering attempts like blocking or spray-painting. It also offers substantial support for the installation of intelligent video applications, such as people counting and heat mapping, through the AXIS camera application platform. -
Convenient video management
The camera's built-in microSDHC card slot enables several days of recording to be stored locally on a memory card. When local storage is used together with the free AXIS camera companion, users have an easy way to remotely view and manage video from up to 16 cameras per site.
- AXIS M3006-V Network Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome - dustproof / vandal-proof
- 8.5 cm x 13.1 cm x 13.1 cm
- 640 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 2048 x 1536
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/3.6"
- Minimum Illumination
- 0.6 lux F2.8
- Focal Length
- 1.6 mm
- Lens Mounting
- M12 mount
- Lens Iris
- Fixed iris
- Panning Range (degree)
- 180
- Tilting Range (degree)
- 45
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, brightness control, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Motion Detection Technology, Virtual Pan/Tilt/Zoom, digital PTZ function
- 1-year warranty
- Environmental Parameters (operating)
- 0 °C - 45 °C; 15 - 85% (non-condensing) relative humidity
- Form Factor
- Dome
- Wired
- 8.5 cm
- 13.1 cm
- 13.1 cm
- 640 g
Camera
- Colour - fixed - dustproof / vandal-proof
- Digital Video Format
- MJPEG, H.264, AVC
- Max Digital Video Resolution
- 2048 x 1536
- Motion Detection
- Video Modes
- 1080p
- Exposure Range
- 2 sec - 1/30500 sec
- 0.6 lux F2.8
- Video Capture
- 2048 x 1536 @ 20 fps
- RAM
- 512 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/3.6"
Lens Construction
- M12 mount
- Focal Length
- 1.6 mm
- Lens Iris
- Fixed iris
- Horizontal Field of View (degree)
- 134
Panning
- Range (degree)
- 180
Tilting
- Range (degree)
- 45
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Included Accessories
- Mounting kit
- C-Tick, VCCI Class B ITE, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, KCC Class B, IP42, IEC 62262 IK08
- Power Requirements
- PoE
- Power Device
- 4.5 Watt
- Limited warranty - 1 year
- 0 °C
- 45 °C
- Relative Humidity (operating)
- 15 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
