The palm-sized AXIS M3005-V Network Camera is an easy-to-install indoor fixed dome that supports HDTV 1080p and 2 MP resolution. It is ideal for retail stores, hotels, schools, banks and offices.
Easy and flexible installation
AXIS M3005-V is vandal- and dust-resistant, and designed for quick and flexible installation. With a 3-axis camera angle adjustment, the cameras can be mounted on walls or ceilings, and images can be easily leveled. -
Convenient video management
AXIS M3005-V offers a convenient video management solution with its built-in micro-SDHC memory card slot for edge storage and support for software such as the complimentary AXIS Camera Companion. Video streams can be encoded in H.264 and Motion JPEG.
- AXIS M3005-V Network Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome - dustproof / vandal-proof
- 5.1 cm x 10 cm x 10 cm
- 200 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/2.7"
- Minimum Illumination
- 1.5 lux F2.8
- Focal Length
- 2.8 mm
- Lens Mounting
- M12 mount
- Lens Iris
- Fixed iris
- Panning Range (degree)
- 175
- Tilting Range (degree)
- 56
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, brightness control, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Motion Detection Technology, Virtual Pan/Tilt/Zoom, digital PTZ function
- 1-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 15 - 85% (non-condensing) relative humidity
- Form Factor
- Dome
- Wired
- 5.1 cm
- 10 cm
- 10 cm
- 200 g
Camera
- Colour - fixed - dustproof / vandal-proof
- Digital Video Format
- MJPEG, H.264, AVC
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Exposure Range
- 1/6 sec - 1/8000 sec
- 1.5 lux F2.8
- Video Capture
- 1920 x 1080 @ 30 fps
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/2.7"
Lens Construction
- M12 mount
- Focal Length
- 2.8 mm
- Lens Iris
- Fixed iris
- Horizontal Field of View (degree)
- 118
Panning
- Range (degree)
- 175
Tilting
- Range (degree)
- 56
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
- Interfaces Details
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Included Accessories
- Mounting kit
- C-Tick, VCCI Class B ITE, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, KCC Class B, IP42, IEC 62262 IK08
- Power Requirements
- PoE
- Power Device
- 2.7 Watt
- Limited warranty - 1 year
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 15 - 85% (non-condensing)
