Your basket is empty
Axis M3005-V Network Camera
Quicklinx: 8JPPWS00 Mfr#: 0517-001
  • SDHC Memory Card
The palm-sized AXIS M3005-V Network Camera is an easy-to-install indoor fixed dome that supports HDTV 1080p and 2 MP resolution. It is ideal for retail stores, hotels, schools, banks and offices.
AXIS M3005-V Network Camera - network surveillance camera
Network surveillance camera - fixed dome - dustproof / vandal-proof
5.1 cm x 10 cm x 10 cm
200 g
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/2.7"
Minimum Illumination
1.5 lux F2.8
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
Fixed iris
Panning Range (degree)
175
Tilting Range (degree)
56
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Backlight compensation, sharpness control, digital image rotation, white balance, colour control, brightness control, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Motion Detection Technology, Virtual Pan/Tilt/Zoom, digital PTZ function
1 year warranty
Environmental Parameters (operating)
0 °C - 40 °C; 15 - 85% (non-condensing) relative humidity
Wired
5.1 cm
10 cm
10 cm
200 g
Camera
Colour - fixed dome - dustproof / vandal-proof
Digital Video Format
MJPEG, H.264, AVC
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Exposure Range
1/6 sec - 1/8000 sec
1.5 lux F2.8
Video Capture
1920 x 1080 @ 30 fps
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/2.7"
Lens Construction
M12 mount
Focal Length
2.8 mm
Lens Iris
Fixed iris
Horizontal Field of View (degree)
118
Panning
Range (degree)
175
Titling
Range (degree)
56
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Mounting kit
C-Tick, VCCI Class B ITE, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, KCC Class B, IP42, IEC 62262 IK08
Power Requirements
PoE
2.7 Watt
Limited warranty - 1 year
Relative Humidity (operating)
