AXIS M2014-E is a high-performance, compact bullet-style network camera, designed for maximum flexibility and ease of installation. The camera's functional and compact form factor makes it perfect for installations in retail stores, boutiques, hotels and small offices. The camera has a unique design concept comprising a main unit and a separate camera unit, which allows these units to be mounted up to 8 meters (26 feet) apart, providing flexibility to place the camera unit in one place and the main unit elsewhere.
AXIS M2014-E offers a small-scale, convenient video management solution with its built-in micro-SDHC memory card slot for edge storage and support for AXIS camera companion. AXIS M2014-E supports intelligent video features such as motion detection, tampering alarm and I/O ports for connecting external devices. In addition, AXIS camera application platform support is also provided.
Stylish and functional design
AXIS M2014-E is a high-performance, compact bullet-style network camera, designed for maximum flexibility and ease of installation. The camera's functional and compact form factor makes it perfect for installations in retail stores, boutiques, hotels and small offices. -
Easy and flexible installation
The camera has a unique design concept comprising a main unit and a separate camera unit, which allows these units to be mounted up to 8 meters (26 feet) apart, providing flexibility to place the camera unit in one place and the main unit elsewhere. -
Convenient video management solution
AXIS M2014-E offers a small-scale, convenient video management solution with its built-in micro-SDHC memory card slot for edge storage and support for AXIS camera companion. -
Intelligent video capabilities
- AXIS M2014-E Network Camera - network surveillance camera
- Network surveillance camera - fixed - outdoor - dustproof / waterproof
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1280 x 720
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 720p
- Optical Sensor Type
- CMOS - 1/4"
- Minimum Illumination
- 1 lux F2.0
- Focal Length Control
- Fixed focal
- Focal Length
- 2.8 mm
- Lens Iris
- F/2.0 - fixed iris
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 8 - 28 V / PoE
- Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, auto exposure control, colour control, progressive scanning, brightness control, contrast control, e-mail alerts, image mirror, AXIS Video Hosting System (AVHS), Privacy Mask Function, Video Motion Detection Technology, active tampering alarm, ONVIF V2.2 (Profile S) support, password protection
- 1-year warranty
- Environmental Parameters (operating)
- -20 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
- Wired
Camera
- Colour - fixed - outdoor - dustproof / waterproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Video Modes
- 720p
- Exposure Range
- 1/6 sec - 1/24500 sec
- 1 lux F2.0
- Frame Rate (max)
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/4"
Lens Construction
- Fixed focal
- Focal Length
- 2.8 mm
- Lens Iris
- F/2.0 fixed iris
- Horizontal Field of View (degree)
- 81
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
- Alarm Inputs Qty
- 1
- Alarm Outputs Qty
- 1
- Ports
- LAN/power - RJ-45
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Included Accessories
- Mounting kit
- C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, IEC 60950-1, EN 60950-1, IEC 60068-2-30, IEC 60068-2-27, IEC 60068-2-6, IP66, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, VCCI Class B, KN24, AS/NZS CISPR 22, IEC 60950-22, EN 60950-22, UL 60950-22, KCC KN22 Class B
- Power Requirements
- DC 8 - 28 V / PoE
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year
- -20 °C
- 50 °C
- Relative Humidity (operating)
- 10 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
