AXIS M1124 offers a professional and affordable fixed camera suitable for a wide range of video surveillance applications, such as for retail and banking as well as libraries and other office buildings. It can be used indoors, as well as in an outdoor housing.
Images optimized for forensic analysis
Supporting WDR - Forensic Capture capability, the video is highly optimized for forensic purposes and provides extreme levels of detail - even in scenes with very complex light conditions. Thanks to the automatic IR-cut filter, AXIS M1124 can deliver images both day and night. Furthermore, the network camera includes the ability to seamlessly transition between WDR and low-light mode. -
More video, less storage
AXIS M1125 incorporates Axis' Zipstream technology, which is a radically more efficient H.264 implementation, lowering bandwidth and storage requirements by an average 50% or more for many common 24/7 surveillance use cases.
- AXIS M1124 Network Camera - network surveillance camera
- Network surveillance camera - fixed
- 4.4 cm x 7 cm x 14.8 cm
- 200 g
- White
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 3.5 x
- Max Resolution
- 1280 x 720
- Motion Detection
- Video Modes
- 720p
- Optical Sensor Type
- CMOS - 1/2.8"
- Minimum Illumination
- 0.25 lux - colour - F1.4 , 0.05 lux - B&W - F1.4
- Focal Length Control
- Vari-focal
- Focal Length
- 3 mm - 10.5 mm
- Lens Mounting
- CS-mount
- Lens Iris
- F/1.4 - auto iris (DC)
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 8 - 28 V / PoE
- Sharpness control, white balance, colour control, brightness control, contrast control, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), infrared cut filter, Video Motion Detection Technology, active tampering alarm, digital PTZ function, LED indicator, password protection, IR Corrected lens, Variable Bitrate (VBR)
- 1-year warranty
- Environmental Parameters (operating)
- -20 °C - 50 °C; 10 - 80% (non-condensing) relative humidity
- Wired
- 4.4 cm
- 7 cm
- 14.8 cm
- 200 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Video Modes
- 720p
- Exposure Range
- 2 sec - 1/143000 sec
- Digital Video Capture Resolution
- 160 x 90
- RAM
- 512 MB
- Flash Memory
- 256 MB
Image Sensor
- CMOS 1/2.8"
Lens Construction
- CS-mount - vari-focal
- Optical Zoom
- 3.5 x
- Focal Length
- 3 mm - 10.5 mm
- Lens Iris
- F/1.4 auto iris (DC)
- Horizontal Field of View (degree)
- 32 - 91
- Vertical Field of View (degree)
- 18 - 49
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Included Accessories
- Stand
- C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, EN 61000-6-1, ICES-003 Class A, EN 61000-6-2, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60068-2-30, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, EN 50121-4, VCCI Class A, EN 50581, KN24, KCC KN22, AS/NZS CISPR22:2004 Class A, EN 55022 Class A
- White
- Power Requirements
- DC 8 - 28 V / PoE
- Limited warranty - 1 year
- -20 °C
- 50 °C
- Relative Humidity (operating)
- 10 - 80% (non-condensing)
