Your basket is empty
Axis M1124 Network Camera Network Surveillance Camera
Quicklinx: C0LTWS00 Mfr#: 0747-001
  • microSD Card
  • microSDHC Card
AXIS M1124 offers a professional and affordable fixed camera suitable for a wide range of video surveillance applications, such as for retail and banking as well as libraries and other office buildings. It can be used indoors, as well as in an outdoor housing.
AXIS M1124 Network Camera - network surveillance camera
Network surveillance camera - fixed
4.4 cm x 7 cm x 14.8 cm
200 g
White
Wired
Camera
Colour - Day&Night
Optical Zoom
3.5 x
Max Resolution
1280 x 720
Motion Detection
Video Modes
720p
Optical Sensor Type
CMOS - 1/2.8"
Minimum Illumination
0.25 lux - colour - F1.4 , 0.05 lux - B&W - F1.4
Focal Length Control
Vari-focal
Focal Length
3 mm - 10.5 mm
Lens Mounting
CS-mount
Lens Iris
F/1.4 - auto iris (DC)
Ethernet 10Base-T/100Base-TX
Voltage
DC 8 - 28 V / PoE
Sharpness control, white balance, colour control, brightness control, contrast control, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), infrared cut filter, Video Motion Detection Technology, active tampering alarm, digital PTZ function, LED indicator, password protection, IR Corrected lens, Variable Bitrate (VBR)
1 year warranty
Environmental Parameters (operating)
-20 °C - 50 °C; 10 - 80% (non-condensing) relative humidity
Wired
4.4 cm
7 cm
14.8 cm
200 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
Video Modes
720p
Exposure Range
2 sec - 1/143000 sec
RAM
512 MB
Flash Memory
256 MB
Image Sensor
CMOS 1/2.8"
Lens Construction
CS-mount - vari-focal
Optical Zoom
3.5 x
Focal Length
3 mm - 10.5 mm
Lens Iris
F/1.4 auto iris (DC)
Horizontal Field of View (degree)
32 - 91
Vertical Field of View (degree)
18 - 49
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Stand
C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, EN 61000-6-1, ICES-003 Class A, EN 61000-6-2, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60068-2-30, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, EN 50121-4, VCCI Class A, EN 50581, KN24, KCC KN22, AS/NZS CISPR22:2004 Class A, EN 55022 Class A
White
Power Requirements
DC 8 - 28 V / PoE
Limited warranty - 1 year
-20 °C
50 °C
Relative Humidity (operating)
C0LT C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.09
C0LT C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.60
C0LT C2G 2m Cat6a Shielded Patch - Blue In Stock £6.53
C0LT C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.38
