Your basket is empty
AXIS M1034-W Network Camera
Quicklinx: 9KVQWS00 Mfr#: 0522-003
AXIS M1034-W offers the choice of either a wireless or a wired connection to the network. It features Wi-Fi Protected Setup protocol, which simplifies the process of configuring logical security on wireless networks. The combination of the wireless 802.11 b/g/n standard and the WPS protocol assures user-friendliness and high network security, while enabling HDVT video to be streamed reliably over a wireless network.
AXIS M1034-W Network Camera - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
5.9 cm x 4.1 cm x 9.5 cm
118 g
White
Wired, wireless
Camera
Max Resolution
1280 x 800
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
1.2 lux F2.0
Focal Length
2.8 mm
Lens Iris
F/2.0 - fixed iris
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Motion sensor, sharpness control, digital image rotation, white balance, colour control, alarm function, brightness control, contrast control, image mirror, built-in LED illuminator, Wi-Fi Protected Setup (WPS), digital PTZ function
1 year warranty
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wired, wireless
5.9 cm
4.1 cm
9.5 cm
118 g
United Kingdom
Camera
Colour - fixed
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1280 x 800
Exposure Range
1/6 sec - 1/8000 sec
1.2 lux F2.0
Video Capture
1280 x 800 @ 30 fps , 320 x 240 @ 30 fps
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/4"
Lens Construction
Focal Length
2.8 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
80
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, QOS, CIFS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15 B, AS/NZS 4771, RSS-210, FCC Part 15 C, EN 61000-6-2, IEC 60950-1, EN 60950-1, ANATEL, TELEC, KCC Class B, EN 62311
White
Power Requirements
DC 5 V
Power adapter - external
Software Included
Drivers & Utilities
Limited warranty - 1 year
Relative Humidity (operating)
9KVQ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.08
9KVQ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.53
9KVQ C2G 2m Cat6a Shielded Patch - Blue In Stock £6.47
9KVQ C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.04
