Product
Axis M1014 Network Camera - Network camera - colour - fixed iris
Quicklinx: 89T8WS00 Mfr#: 0520-003
AXIS M1014 network camera supports edge storage, which includes support for storage on microSDHC cards as well as recording to network shares such as Network-Attached Storage (NAS). Video intelligence includes video motion detection and active tampering alarm. Together with AXIS Camera Companion, AXIS M1014 offers a very price competitive solution. The network camera is ideal for securing locations such as small businesses, boutiques, restaurants, hotels or residences. It offers superior video quality in its class at 30 frames per second in 1 megapixel or HDTV 720p resolution.
AXIS M1014 provides multiple, individually configurable video streams in H.264 as well as motion JPEG. Full frame rate and resolution is provided in either compression. The H.264 compression enables optimization for bandwidth and storage efficiency by significantly reducing the bit rate.
  • Small and functional camera design
  • High-performance compression and streaming capabilities
  • Easy and flexible installation
    The mounting stand can be installed on wall and ceiling. A mounting clamp allows the camera to be installed in shelves.
AXIS M1014 Network Camera - network surveillance camera
Network surveillance camera - fixed
5.9 cm x 3.4 cm x 9.5 cm
110 g
Wired
Camera
Max Resolution
1280 x 800
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
1.2 lux F2.0
Focal Length
2.8 mm
Focus Adjustment
Manual
Lens Iris
F/2.0 - fixed iris
Ethernet 10Base-T/100Base-TX
Voltage
DC 5 V
Backlight compensation, sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, contrast control, image mirror, Privacy Mask Function, microSDHC card slot, NAS-Ready
1 year warranty
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Wired
5.9 cm
3.4 cm
9.5 cm
110 g
United Kingdom
Camera
Colour - fixed
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1280 x 800
Exposure Range
1/8000 sec - 1/6 sec
1.2 lux F2.0
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/4"
Lens Construction
Focal Length
2.8 mm
Lens Iris
F/2.0 fixed iris
Focus Adjustment
Manual
Horizontal Field of View (degree)
80
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, QOS, CIFS
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, EN 60950-1, KCC Class B
Power Requirements
DC 5 V
Power adapter - external
Software Included
Drivers & Utilities
Limited warranty - 1 year
Relative Humidity (operating)
89T8 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.17
89T8 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.27
89T8 C2G 2m Cat6a Shielded Patch - Blue In Stock £6.93
89T8 C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £44.73
