AXIS M1014 network camera supports edge storage, which includes support for storage on microSDHC cards as well as recording to network shares such as Network-Attached Storage (NAS). Video intelligence includes video motion detection and active tampering alarm. Together with AXIS Camera Companion, AXIS M1014 offers a very price competitive solution. The network camera is ideal for securing locations such as small businesses, boutiques, restaurants, hotels or residences. It offers superior video quality in its class at 30 frames per second in 1 megapixel or HDTV 720p resolution.
AXIS M1014 provides multiple, individually configurable video streams in H.264 as well as motion JPEG. Full frame rate and resolution is provided in either compression. The H.264 compression enables optimization for bandwidth and storage efficiency by significantly reducing the bit rate.
Small and functional camera design
AXIS M1014 network camera supports edge storage, which includes support for storage on microSDHC cards as well as recording to network shares such as Network-Attached Storage (NAS). Video intelligence includes video motion detection and active tampering alarm. Together with AXIS Camera Companion, AXIS M1014 offers a very price competitive solution. The network camera is ideal for securing locations such as small businesses, boutiques, restaurants, hotels or residences. It offers superior video quality in its class at 30 frames per second in 1 megapixel or HDTV 720p resolution. -
High-performance compression and streaming capabilities
AXIS M1014 provides multiple, individually configurable video streams in H.264 as well as motion JPEG. Full frame rate and resolution is provided in either compression. The H.264 compression enables optimization for bandwidth and storage efficiency by significantly reducing the bit rate. -
Easy and flexible installation
The mounting stand can be installed on wall and ceiling. A mounting clamp allows the camera to be installed in shelves.
- AXIS M1014 Network Camera - network surveillance camera
- Network surveillance camera - fixed
- 5.9 cm x 3.4 cm x 9.5 cm
- 110 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1280 x 800
- Optical Sensor Type
- CMOS - 1/4"
- Minimum Illumination
- 1.2 lux F2.0
- Focal Length
- 2.8 mm
- Focus Adjustment
- Manual
- Lens Iris
- F/2.0 - fixed iris
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 5 V
- Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, contrast control, image mirror, Privacy Mask Function, microSDHC card slot, NAS-Ready
- 1-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Wired
- 5.9 cm
- 3.4 cm
- 9.5 cm
- 110 g
- Localisation
- United Kingdom
Camera
- Colour - fixed
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 800
- Exposure Range
- 1/8000 sec - 1/6 sec
- 1.2 lux F2.0
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/4"
Lens Construction
- Focal Length
- 2.8 mm
- Lens Iris
- F/2.0 fixed iris
- Focus Adjustment
- Manual
- Horizontal Field of View (degree)
- 80
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, QOS, CIFS
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Stand
- C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, EN 60950-1, KCC Class B
- Power Requirements
- DC 5 V
- Power Device
- Power adapter - external
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
