Axis Companion Wireless Day/Nigh Full HD Cube Camera
Quicklinx: D5HSWS00 Mfr#: 0892-003
  • microSDHC Card
  • microSD Card
AXIS Companion Cube LW features high quality video in HDTV 1080p/2 MP resolution and WDR. It comes with IR illumination, day/night functionality, PIR motion sensor, microphone and mini-speaker. The camera connects over wireless LAN (IEEE 802.11 a/b/g/n) or wired Ethernet. It supports Wi-Fi Protected Setup with push button configuration. AXIS Companion Cube LW is optimized for edge storage and with AXIS Companion Card 64 GB included it is a self-contained recording solution. Axis Zipstream technology allows even high quality video to be recorded effectively. AXIS Companion Cube LW is supported only by AXIS Companion video management software and mobile app.
AXIS Companion Cube LW - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
6 cm x 3.7 cm x 10.6 cm
128 g
White
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/3" - 2 MP
Minimum Illumination
0.25 lux - colour - F2.0 - 50 IRE , 0.05 lux - B&W - F2.0 - 50 IRE , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0 - fixed iris
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a
Voltage
DC 4.75 - 5.25 V
Exposure compensation, sharpness control, digital image rotation, white balance, colour control, brightness control, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), infrared cut filter, built-in IR illuminator, PIR-based motion detector, Video Motion Detection Technology, password protection, Variable Bitrate (VBR), Zipstream technology
3-year warranty
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 85% (non-condensing) relative humidity
Audio Support
Wired, wireless
6 cm
3.7 cm
10.6 cm
128 g
United Kingdom
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG, H.264, MPEG-4 AVC
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Exposure Range
1/5 sec - 1/32500 sec
Frame Rate (max)
RAM
512 MB
Flash Memory
256 MB
Image Sensor
2 MP CMOS 1/3"
Lens Construction
M12 mount - fixed focal
Focal Length
2.8 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
110
Vertical Field of View (degree)
61
Network Interface
Network Protocols
DHCP, HTTP, NTP, TCP/IP, UDP/IP, ARP, ICMP, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, CIFS
Ports
LAN - RJ-45 , USB (power only)
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
64 GB microSD card
EN 61000-3-2, EN 61000-3-3, EN55024, FCC Part 15 B, EMC, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, VCCI Class B, KN24, RCM, IEC 62471, KN35, EN 55032 Class B, AS/NZS CISPR 32 Class B
White
Power Requirements
DC 4.75 - 5.25 V
Limited warranty - 3 years
Relative Humidity (operating)
