360° indoor surveillance
From retail stores to small offices, AXIS Companion 360 is ideal for any location where high quality overview surveillance helps protect your business. -
Get a better view
With one single camera, you get outstanding 360° panoramic overview of smaller premises. With its advanced sensor and full frame rate, AXIS Companion 360 gives you complete and sharp overview. HDMI output allows for connection to monitors for display of live camera footage. -
Simplified installation
The palm-sized AXIS Companion 360 can be easily installed on walls or ceilings. The camera is delivered factory-focused out of the box, so no focusing is required. The camera features PoE that allows one cable to provide both network connectivity and electrical power.
- AXIS Companion 360 - network surveillance camera - dome
- Network surveillance camera - fixed - dome
- 10.1 cm x 10.1 cm x 4.6 cm
- 240 g
- White
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 2048 x 2048
- Frame Rate (max)
- 60 frames per second
- Motion Detection
- Video Modes
- 720p
- Optical Sensor Type
- RGB CMOS - 1/1.8" - 6 MP
- Minimum Illumination
- 0.3 lux F2.8 - 50 IRE
- Focal Length
- 1.6 mm
- Lens Iris
- F/2.8 - fixed iris
- HDMI, Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Sharpness control, white balance, colour control, brightness control, contrast control, image mirror, Wide Dynamic Range (WDR), lens preset positioning, Privacy Mask Function, NAS-Ready, Video Motion Detection Technology, digital PTZ function, password protection, advanced de-warping technology, Variable Bitrate (VBR), noise reduction, Zipstream technology, image overlay, exposure control, Pixel Counter Support, digest authentication, Axis Secure Remote Access, exposure zone
- 3-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 10 - 85% (non-condensing) relative humidity
- Form Factor
- Dome
- Wired
- 10.1 cm
- 10.1 cm
- 4.6 cm
- 240 g
Camera
- Colour - fixed
- Digital Video Format
- MJPEG, H.264, MPEG-4 AVC
- Max Digital Video Resolution
- 2048 x 2048
- Motion Detection
- Video Modes
- 720p
- Exposure Range
- 1/2 sec - 1/31500 sec
- Digital Video Capture Resolution
- 640 x 240, 1920 x 1440, 480 x 480, 2304 x 1296, 480 x 360, 2048 x 2048, 1920 x 720, 2304 x 648
- Frame Rate (max)
- RAM
- 1024 MB
- Flash Memory
- 256 MB
Image Sensor
- 6 MP RGB CMOS 1/1.8"
Lens Construction
- Focal Length
- 1.6 mm
- Lens Iris
- F/2.8 fixed iris
- Horizontal Field of View (degree)
- 185
- Vertical Field of View (degree)
- 185
- Video
- HDMI
- Network Interface
- Ethernet 10Base-T/100Base-TX
- Network Protocols
- DHCP, DNS, HTTP, NTP, TCP/IP, UDP/IP, ARP, SOCKS, RTSP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, CIFS
- Ports
- HDMI , LAN/power - RJ-45
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Included Accessories
- Drill hole template
- CISPR 22 Class A, EN55024, EN 61000-6-1, ICES-003 Class A, EN 61000-6-2, IEC 60068-2-27, IEC 60068-2-6, FCC Part 15 B Class A, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, VCCI Class A, KN35, EN 62368-1, IEC 62368-1, EN 55032 Class A, KCC KN32 Class A, IEEE 802.3af, IEEE 802.3at, UL 62368-1, IEC 60068-2-2-78
- White
- Power Requirements
- PoE
- Power Device
- 6.49 Watt
- Software Included
- Windows decoder 1-user licence
- Limited warranty - 3 years
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 10 - 85% (non-condensing)
