Axis Companion Ultra Compact Indoor 360 Mini Dome Camera
Quicklinx: D5HZWS00 Mfr#: 01024-001
  • microSDHC Card
  • microSD Card
£271.67 ex VAT
£326.00 inc VAT
AXIS Companion 360 Network surveillance camera.
  • 360° indoor surveillance
    From retail stores to small offices, AXIS Companion 360 is ideal for any location where high quality overview surveillance helps protect your business.
  • Get a better view
    With one single camera, you get outstanding 360° panoramic overview of smaller premises. With its advanced sensor and full frame rate, AXIS Companion 360 gives you complete and sharp overview. HDMI output allows for connection to monitors for display of live camera footage.
  • Simplified installation
    The palm-sized AXIS Companion 360 can be easily installed on walls or ceilings. The camera is delivered factory-focused out of the box, so no focusing is required. The camera features PoE that allows one cable to provide both network connectivity and electrical power.
AXIS Companion 360 - network surveillance camera
Network surveillance camera - fixed dome
10.1 cm x 10.1 cm x 4.6 cm
240 g
White
Wired
Camera
Max Resolution
2048 x 2048
Frame Rate (max)
60 frames per second
Motion Detection
Video Modes
720p
Optical Sensor Type
RGB CMOS - 1/1.8" - 6 MP
Minimum Illumination
0.3 lux F2.8 - 50 IRE
Focal Length
1.6 mm
Lens Iris
F/2.8 - fixed iris
HDMI, Ethernet 10Base-T/100Base-TX
Voltage
PoE
Sharpness control, white balance, colour control, brightness control, contrast control, image mirror, Wide Dynamic Range (WDR), lens preset positioning, Privacy Mask Function, NAS-Ready, Video Motion Detection Technology, digital PTZ function, password protection, advanced de-warping technology, Variable Bitrate (VBR), noise reduction, Zipstream technology, image overlay, exposure control, Pixel Counter Support, digest authentication, Axis Secure Remote Access, exposure zone
3-year warranty
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 85% (non-condensing) relative humidity
Wired
10.1 cm
10.1 cm
4.6 cm
240 g
Camera
Colour - fixed dome
Digital Video Format
MJPEG, H.264, MPEG-4 AVC
Max Digital Video Resolution
2048 x 2048
Motion Detection
Video Modes
720p
Exposure Range
1/2 sec - 1/31500 sec
Digital Video Capture Resolution
640 x 240, 1920 x 1440, 480 x 480, 2304 x 1296, 480 x 360, 2048 x 2048, 1920 x 720, 2304 x 648
Frame Rate (max)
RAM
1024 MB
Flash Memory
256 MB
Image Sensor
6 MP RGB CMOS 1/1.8"
Lens Construction
Focal Length
1.6 mm
Lens Iris
F/2.8 fixed iris
Horizontal Field of View (degree)
185
Vertical Field of View (degree)
185
Video
HDMI
Network Interface
Network Protocols
DHCP, DNS, HTTP, NTP, TCP/IP, UDP/IP, ARP, SOCKS, RTSP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, CIFS
Ports
HDMI , LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Drill hole template
CISPR 22 Class A, EN55024, EN 61000-6-1, ICES-003 Class A, EN 61000-6-2, IEC 60068-2-27, IEC 60068-2-6, FCC Part 15 B Class A, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, VCCI Class A, KN35, EN 62368-1, IEC 62368-1, EN 55032 Class A, KCC KN32 Class A, IEEE 802.3af, IEEE 802.3at, UL 62368-1, IEC 60068-2-2-78
White
Power Requirements
PoE
6.49 Watt
Software Included
Windows decoder 1-user licence
Limited warranty - 3 years
Relative Humidity (operating)
Brand: Axis
Price Range Ex VAT: 150 - 300
