Axis Companion Recorder 8 Channel 4TB
Quicklinx: D5J3WS00 Mfr#: 0893-003
£549.22 ex VAT
£659.06 inc VAT
AXIS Companion Recorder is a compact network video recorder for up to eight Axis network cameras. It includes a built in PoE switch for easy installation. The device features a surveillance grade hard disk and a fanless design. It also includes a USB port for easy export of video footage. A wireless access point is included for installation and direct access to the system with mobile devices.
  • Sufficient storage for your surveillance system
    A surveillance solution with AXIS Companion Line cameras that utilize Axis' Zipstream technology, the retention time of AXIS Companion Recorder is between 1 to 2 months, depending on the surveillance scene.
  • Compact storage device for HDTV surveillance
    AXIS Companion Recorder is a compact network video recorder for up to eight Axis network cameras. It includes a built in PoE switch for easy installation. The device features a surveillance-grade hard disk and a fan-less design. Is also includes a USB port for easy export of video footage and a wireless access point for installation and direct access to the system with mobile devices.
AXIS Companion Recorder - standalone NVR - 8 channels
NVR - 8 channels
IP Cameras Supported
8
Compression Format
MPEG-4, H.264
Hard Drive
1 x 4 TB
Hard Drive(s) Supported
Quantity: 1
Voltage
120 / 230 V
18 cm x 18 cm x 5.3 cm
600 g
Country Kits
United Kingdom
3 years
NVR
Video Channels
8
8
Compression Format
MPEG-4, H.264
Package Content
Manual, DVR, external power adapter
Country Kits
United Kingdom
EN 61000-3-2, EN 61000-3-3, EN55024, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EMC, FCC Part 15 C, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 E, EN 300 328, EN 301489-1, EN 301489-17, RSS-247, EN 55032 Class B, EN 301 893
White
Warranty
3 years
Security DVR
Fanless
Hard Drive
Quantity Installed
1
Quantity Supported
1
4 TB
Serial ATA
Video Server
RAM
512 MB
Flash Memory
256 MB
Network Interfaces
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a
Supported Protocols
DHCP, DNS, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, TLS, Bonjour, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
Power over Ethernet (PoE), WPA2 encryption, audible alarm notification, e-mail notification
Network Port
10/100Base-TX x 8 (PoE) / 10/100Base-TX x 1
Other Ports
USB 2.0
Voltage
120 / 230 V
Frequency
50/60 Hz
Power Consumption
90 Watt
18 cm
18 cm
5.3 cm
600 g
35 °C
10 - 85% (non-condensing)
Brand: Axis
Price Range Ex VAT: 500 - 750
