Axis Companion Ourdoor Ready Full HD Mini Dome Camera
Quicklinx: D5HWWS00 Mfr#: 0880-001
  • microSDHC Card
  • microSD Card
23 in stock
£244.66 ex VAT
£293.59 inc VAT
AXIS Companion Eye LVE Network surveillance camera an a dome for outdoor use. It is vandal and weather proof for Day & Night.
AXIS Companion Eye LVE - network surveillance camera
Network surveillance camera - fixed dome - outdoor - vandal / weatherproof
10.1 cm x 10.1 cm x 9.4 cm
380 g
White
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/2.8"
Minimum Illumination
0.2 lux - colour - F2.0 - 50 IRE , 0.04 lux - B&W - F2.0 - 50 IRE , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0 - fixed iris
Panning Range (degree)
-180 to +180
Tilting Range (degree)
0 to 60
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Sharpness control, digital image rotation, white balance, auto exposure control, colour control, progressive scanning, brightness control, contrast control, image mirror, Wide Dynamic Range (WDR), infrared cut filter, NAS-Ready, Video Motion Detection Technology, password protection, Edge Storage, Variable Bitrate (VBR), video analytics, Zipstream technology, Access Control
3-year warranty
Environmental Parameters (operating)
-30 °C - 50 °C; 10 - 100% relative humidity
Wired
10.1 cm
10.1 cm
9.4 cm
380 g
Camera
Colour - Day&Night - fixed dome - outdoor - vandal / weatherproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Exposure Range
2 sec - 1/66500 sec
Infrared LEDs
Infrared Distance
15 m
Digital Video Capture Resolution
176 x 120, 1920 x 1080
Frame Rate (max)
RAM
512 MB
Flash Memory
256 MB
Image Sensor
CMOS 1/2.8"
Lens Construction
M12 mount - fixed focal
Focal Length
2.8 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
118
Vertical Field of View (degree)
65
Panning
Range (degree)
-180 to +180
Titling
Range (degree)
0 to 60
Network Interface
Network Protocols
DHCP, HTTP, NTP, TCP/IP, UDP/IP, ARP, ICMP, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, CIFS
Ports
LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
EN55024, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, NEMA Type 4X, EN 61000-6-2, IEC 60068-2-27, IEC 60068-2-6, IP66, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, IEC 62262 IK08, VCCI Class B, RCM, IEC 60950-22, IEC 62471, EN 60950-22, UL 60950-22, AS/NZS CISPR 22 Class B, FCC Part 15 Class B, KN35, KCC KN32 Class B, IEC 60721-3-4 Class 4M3
White
Power Requirements
PoE
4.2 Watt
Limited warranty - 3 years
-30 °C
50 °C
Relative Humidity (operating)
10 - 100%
Brand: Axis
Price Range Ex VAT: 150 - 300
