AXIS P7701 Video Decoder
Quicklinx: 78YKWS00 Mfr#: 0319-002
The AXIS P7701 Video Decoder provides a simple monitoring solution by enabling analog or digital monitors/projectors to connect to and display live video from Axis network cameras and video encoders. In situations where only live video display is required - such as with a public view monitor at a store entrance, AXIS P7701 offers a more cost-effective solution than using a PC for connecting a monitor. AXIS P7701 can also complement a video management system by helping to offload the main server from decoding digital streams simply for display purposes.
  • Simple monitoring solution for Axis network video products
  • Full frame rate video decoding of H.264, MPEG-4 and motion JPEG
    AXIS P7701 can decode full frame rate video streams in H.264 and MPEG-4 in all resolutions up to D1. Motion JPEG can be decoded in all resolutions up to 720p (1280 x 720). The video decoder can provide either digital or analog video output. Video from any number of cameras can be shown in sequence.
  • Alarm-triggered video and high-quality audio
    When an alarm is triggered in a network camera or video encoder, AXIS P7701 can be configured to automatically display alarm-triggered video. AXIS P7701 also decodes mono audio. The video decoder can be powered either through Power over Ethernet or through an external power supply.
AXIS P7701 Video Decoder - video decoder - 1 channels
Video decoder - 1 channels
Compression Format
MJPEG, MPEG-4, G.711, G.726, H.264, AAC
TV System
NTSC/PAL
Image Resolution
720x480 (NTSC), 720x576 (PAL)
9.9 cm x 11.8 cm x 3.2 cm
320 g
Country Kits
United Kingdom, Europe
Video decoder
Video Channels
1
Audio Channels
1
TV System
NTSC/PAL
Image Resolution
Compression Format
Package Content
Manual, external power adapter, software, video server, mounting kit, connector kit
Software Included (Y)
Drivers & Utilities
Country Kits
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, EN 60950-1
DDNS Support
Web Server
Supported Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, HTTP over SSL, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, Bonjour, RTCP, IGMP
Power over Ethernet (PoE), IP address filtering
Video Output Ports
DVI-I x 1, RCA x 1
Audio Output Ports
Mini-phone 3.5 mm x 1
Camera Control Interface (PTZ)
RS-422/485
Network Port
10/100Base-T
Power Consumption
8.3 Watt
9.9 cm
11.8 cm
3.2 cm
320 g
50 °C
20 - 80%
