Avocent USB,Dual DVI-I, audio desktop user station
Quicklinx: 7RDXWS00 Mfr#: HMX2050-201
£906.79 ex VAT
£1,088.14 inc VAT
The Avocent HMX series eliminates the distance limitations found in analog extenders. The HMX 2050 delivers high-quality dual-head video with 1920x1200 60 Hz resolution. The HMX 2050 enhances safety and security by enabling monitors, keyboard, mouse and speakers at a convenient desktop location while your computer resides in a physically secure location on the network.
  • Eliminates distance limitations within the LAN
    Allows computers and users to be located anywhere on the network.
  • High-quality DVI video and CD audio
    For intensive graphic and audio applications.
  • Centralized management
    Via a single console, including access, desktop pooling and reporting.
  • Centralized, user-rights management
    HMX system allows user administration and authentication through AD, LDAP, TACACS+, RADIUS, RSA SecureID and NT.
  • Greater security
    128bit AES encryption for secure access.
  • No dedicated cabling
    Removes the need for dedicated cabling between user and computer.
  • USB support
    USB media and most other USB devices including USB keyboard/mouse as well as vUSB.
  • Interoperability
    Between the HMX extender system and the single- and dual-video, high-resolution products.
Avocent HMX 2050 User Station - monitor/USB/audio extender
Monitor/USB/audio extender
External
Data Transfer Rate
1 Gbps
AC 120/230 V
20.8 cm x 15.4 cm x 2.8 cm
1 kg
External
Wired
Data Transfer Rate
1 Gbps
Max Resolution
1920 x 1200 @ 60 Hz
128-bit encryption
4 x USB - Type A , 2 x DVI-I , 1 x audio (output) - mini jack , 1 x network - RJ-45
UL, cUL, FCC Part 15 A
External power adapter
AC 120/230 V
20.8 cm
15.4 cm
2.8 cm
1 kg
Type: Monitor/USB/audio extender
Ports: 2
Brand: Avocent
Price Range Ex VAT: £750 - £1000
