The NIAP certified Avocent SwitchView SC4 UAD KVM switch supports USB keyboards and mice, audio and DVI-I video for resolution up to 1920x1200 @ 60Hz. Designed for secure environments, this switch includes four fully secure channels. Each of the four secure channels is isolated to 60db. With the SwitchView SC4 UAD switch, you can safely switch between as many as four computers operating at different classification levels, all from one keyboard, monitor and mouse.
Secure design
Includes a full suite of security features that allow a user to safely switch between computers operating at different classification levels without compromising network security. -
Desktop management
Improves work efficiency and saves desktop space by eliminating redundant hardware and cables. -
Physical security
Provides visual indication and prevention of tampering. -
Model variety
Offers multiple combinations of peripheral and video connections and port counts to support varying desktop configurations.
- Avocent Switchview SC4 UAD - KVM / audio switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Users Qty
- 1 local user
- Power
- AC 120/230 V (50/60 Hz)
- 27.9 cm x 27.9 cm x 4.4 cm
- 2.2 kg
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1200 @ 60 Hz
- 4 x DVI-I , 4 x USB Type B , 4 x microphone input mini-jack , 4 x audio output mini-jack , 1 x DVI-I , 2 x USB Type A , 1 x microphone input mini-jack , 1 x audio output mini-jack
- Power Device
- Internal power supply
- Voltage Required
- 60 Watt
- EN 60950, EN50082, EN55022, UL 1950, FCC Part 15 B
- 27.9 cm
- 27.9 cm
- 4.4 cm
- 2.2 kg
- 5 °C
- 40 °C
