Avocent SwitchView SC Switch
Quicklinx: 95TQWS00 Mfr#: SC340-201
£292.51 ex VAT
£351.01 inc VAT
The Avocent SwitchView SC 300 KVM switch series offers proven, secure access for any environment where security is mandatory and expanded USB support is required. The SC 300 series is NIAP validated to EAL4+ and allows for multiple levels of physical security and CAC capability, enabling you to consolidate multiple workstations of varying security classification levels with one keyboard, monitor and mouse without compromising network security.
  • NIAP Common Criteria certification
    The SwitchView SC switch is validated to NIAP Common Criteria EAL 4+ security requirements.
  • Data security
    U.S. custom-designed and loaded firmware; automatically clears the keyboard buffer immediately after data is transmitted through the switch, so no data is ever left in the switch.
  • Physical security
    Tamper-evident tape: a visual indication of an attempt to gain access to the internal components of the switch.
  • Appliance security
    Locked memory: prevents tampering and reprogramming of the firmware.
  • Secure data transmission
    Two to eight secure channels; each channel consists of its own unique processing data path.
  • Desktop management
    Industry leading technology provides for seamless switching between channels; improves work efficiency and saves desktop space by eliminating redundant hardware and cables.
Avocent Switchview SC340 - KVM / audio / USB switch - 4 ports
Ports
4 x KVM / audio
KVM Users Qty
1 local user
Common Access Card (CAC) reader support, locked memory
26.16 cm x 17.78 cm x 5.84 cm
1.5 kg
United Kingdom
3-year warranty
Enclosure Type
Desktop
Ports
4 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2560 x 1600
1 x DVI-I (dual link) , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x audio input mini-jack , 1 x audio output mini-jack , 4 x DVI-I (dual link) , 4 x USB Type B , 4 x audio input mini-jack , 4 x audio output mini-jack , 3 x USB Type A
Internal power supply
17.7 Watt
C-Tick, VCCI Class B ITE, EN 60950, ICES-003, EN 61000-3-3, CISPR 22, FCC Part 15 B, UL 60950-1, CSA C22.2 No. 60950-1, Common Criteria EAL4+
United Kingdom
26.16 cm
17.78 cm
5.84 cm
1.5 kg
Limited warranty - 3 years
Min Storage Temperature
-20 °C
Max Storage Temperature
50 °C
Type: KVM / audio / USB switch
Ports: 4
Brand: Avocent
