Avocent SwitchView MM1 4 Port PS/2 and USB KVM Switch with built-in USB Hub and audio.
Independent switching for KVM and four USB 1.1 hub ports;
Multiplatform USB or PS/2 system support;
Integrated USB hub for sharing of USB peripherals/devices;
Audio Support- share speakers and a microphone;
2048 x 1536 high VGA resolution ideal for desktop graphical applications;
Auto scanning allows easy monitoring of attached computers;
Easily add computers without powering down the KVM switch or attached computers;
Error free boot up with keyboard and mouse emulation;
Compatible with USB or PS/2 computers including Mac G3/G4, iMAC.
- Avocent Switchview MM1 - KVM / audio switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Users Qty
- 1 local user
- 22.1 cm x 10.2 cm x 4.3 cm
- 0.9 kg
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2
- Max Resolution
- 2048 x 1536
- 4 x mini-USB Type B , 4 x headphones mini-jack , 4 x microphone mini-jack , 2 x USB Type A , 4 x VGA HD-15 , 2 x USB Type A , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x VGA HD-15
- Power Device
- External power adapter
- EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, EN 61000-3-3, EN55024, EN55022 Class B, FCC Part 15 B
- 22.1 cm
- 10.2 cm
- 4.3 cm
- 0.9 kg
- Limited warranty - 2 years
