Avocent SwitchView DVI and USB KVM Switch, 4-port with built-in USB 2.0 hub and audio device sharing. Avocent SwitchView DVI 4-port KVM switch easily manages two USB DVI computers from a single USB keyboard, mouse and DVI monitor. With video resolutions up to 1920x1200, the SwitchView DVI delivers crisp images for today's high-end displays. Also, share speakers and microphone between PCs. Includes an integrated USB hub.
Manage four USB DVI computers from a single USB keyboard, mouse and DVI monitor;
Integrated USB 2.0 hub for sharing USB peripherals/devices;
1920 x 1200 video resolution ideal for desktop graphical applications;
Support for high-end applications, including DVI monitor and flat panel;
Support for USB PCs, Mac G3/G4, Imac;
Multimedia support including speaker and microphone;
Auto scanning allows easy monitoring of attached computers;
Easily add computers without powering down the KVM switch or attached computers.
PC access
It access from two to four PCs from a single keyboard, monitor and mouse. -
Audio support
Audio feature enables you to share speakers and a microphone between attached PCs. -
Ease of use
Pushbutton or keyboard hotkeys for channels elections; auto scanning allows easy monitoring of attached computers. -
Hot-plug capability
You can add or remove a desktop PC or laptop without turning off the switch or other attached servers.
- Avocent Switchview DVI - KVM / audio switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Users Qty
- 1 local user
- 25.4 cm x 11.7 cm x 4.3 cm
- 1.4 kg
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1200
- Built-in Devices
- USB Hub
- 4 x mini-USB 2.0 Type B , 4 x DVI-D , 4 x headphones mini-jack , 4 x microphone mini-jack , 2 x USB 2.0 Type A , 1 x DVI-D , 2 x USB 2.0 Type A
- Power Device
- External power adapter
- EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, EN 61000-3-3, EN55024, EN55022 Class B, FCC Part 15 B
- 25.4 cm
- 11.7 cm
- 4.3 cm
- 1.4 kg
- Limited warranty - 2 years
Customer reviews
Write a review for the Avocent SwitchView DVI - 1x4 USB DVI KVM Switch here!
Great KVM but take care with DVI cable lengths and monitor resolutions
Reviewed by Ed. Review Posted 16/10/2007
Great KVM with a March 2007 firmware update available from Avocent to handle MS/Logitech keyboards and mice for extra keys.
Comes with a UK power transformer.
Pros:
It handles high resolution DVI - 1680x1050 in my case.
Supports WinXP and Linux without troubles (haven't tried Solaris but it shouldn't be a problem)
Cons:
Take care with DVI cable lengths when running high resolutions. At 1680x1050 there is no signal using a 5m cable into the KVM and so you need a DVI signal booster.
The KVM doesn't come with any leads. These need to be puchased separately (whether using Avocent all-in-one leads or individual leads)
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
