The cost-efficient SwitchView 1000 8-port KVM switch provides PS/2 or USB connectivity for users and target devices. This single user switch has an on-screen display (OSD) and supports a 2048 x 1536 high video resolution that is ideal for graphical applications. With a 1U high design, the compact SwitchView 1000 8-port switch does not compete for valuable rack space in SMB server rooms. Plus, this KVM rack solution is flash upgradeable for fast and easy updates. The SwitchView 1000 8-port switch password protection feature gives you the benefit of added security access to your business-critical servers.
- Avocent Switchview 1000 - KVM switch - 8 ports
- KVM switch - 8 ports - stackable
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Users Qty
- 1 local user
- On-Screen Display
- 41 cm x 16.5 cm x 4.5 cm
- 1.9 kg
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2
- Max Units In A Stack
- 16
- Max Resolution
- 2048 x 1536
- On-Screen Display
- 8 x KVM HD-15 , 1 x network stack device input DB-15 , 1 x network stack device output DB-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x VGA HD-15 , 2 x USB Type A
- Power Device
- External power adapter
- UL, C-Tick, cUL, FCC
- 41 cm
- 16.5 cm
- 4.5 cm
- 1.9 kg
- 0 °C
- 40 °C
