The Avocent SwitchView Secure KVM switches are field-proven, secure KVM switching solutions for government agencies. SwitchView Secure solutions allow users to switch safely between computers operating at different classification levels from a single set of peripherals, providing continuous access to critical data. With multiple security features, the Avocent KVM Secure Switch design prevents the transfer of data between the connected computers, ensuring data security isn't compromised.
- Avocent Switchview SC540 - KVM / audio switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- IDS
- Power
- AC 120/230 V (50/60 Hz)
- 26.4 cm x 18.3 cm x 6.5 cm
- 1.8 kg
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- Max Resolution
- 2560 x 1600 @ 60 Hz
- IDS
- Status Indicators
- Port status
- 4 x USB Type B , 4 x speakers mini-jack , 4 x microphone input mini-jack , 8 x DVI-I (dual link) , 4 x USB Type A , 1 x speakers mini-jack , 1 x microphone input mini-jack , 2 x DVI-I (dual link)
- Power Device
- Internal power supply
- Voltage Required
- 30 Watt
- FCC Class A certified, UL, cUL, VCCI Class A ITE, ICES-003 Class A, EAL 4+, C-Tick Class A
- Localisation
- United Kingdom
- 26.4 cm
- 18.3 cm
- 6.5 cm
- 1.8 kg
- 5 °C
- 40 °C
