Your basket is empty
Avaya Dual Charger Phone Charging Stand
Quicklinx: 9N80WS00 Mfr#: NTTQ4023E6
WLAN Handset 61xx Dual-slot Desktop Charger charges a "Standard", "Extended" or "Ultra-Extended" Battery Pack inserted into a WLAN Handset 6120/6140 and one spare/loose Battery Pack (any capacity) sequentially. The Dual-slot Desktop Charger also features an integrated USB connection that works with the WLAN Handset Administration Tool software to help ease the setup and configuration of the WLAN Handset.
Avaya Dual Charger - charging stand
Charging stand
7.6 cm x 12.5 cm x 6.5 cm
116 g
12 V
Compatible Mobile Devices
Nortel WLAN Handset 6120, Nortel WLAN Handset 6140
Nortel WLAN Handset 6120, 6140
Charging stand
7.6 cm
12.5 cm
6.5 cm
116 g
Enclosure Colour
Charcoal
12 V
Output connectors
Total 2
EN55024, EN55022 Class A, CSA 22.2 No. 60950, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS 6/6, FCC Part 15 A
