Avaya B149 Conference Phone With Caller ID Charcoal Black
Quicklinx: BD7CWS00 Mfr#: 700501533
The Avaya B149 features Avaya's patented OmniSound 2.0 audio technology, for crystal-clear sound. Save contacts in the phone book and use the conference guide to easily set up multi-party calls or pre-programmed group calls. Use the built-in recording function to record calls on an SD memory card. The Avaya B149 is ideal for use in large settings.
  • Crystal clear sound
    OmniSound audio technology provides clear transmission during meetings - so you and your team don't miss any part of the discussion. Full duplex transmits and receives sound simultaneously to prevent audio clipping; 360° surround sound as well as powerful speakers optimize audio pick-up and broadcasting. Noise suppression filters cut static background noise and an equalizer lets you adjust pitch to suit your preference.
  • Plug and Play simplicity
    Connect the Avaya B149 conference phone to an analog telephone line and to a power outlet and you are ready to go! Quick and easy, it's perfect for making multi-party calls, and a handy phone book to store your key contacts.
  • Flexibility and productivity enhancing features
    Enhance web conferencing, video and other communications environments. The B149 conference phone is a versatile high performer that complements your existing solutions, which can be easily redeployed as your business grows or as needs change.
Avaya B149 - conference phone with caller ID
Conference phone with caller ID
Compatible Platforms
Avaya IP Office, Avaya Communication Server 1000
Package Content
Conference phone console
Speakerphone
Yes (digital duplex)
Caller ID
Call Services
Caller ID, Call Hold
Display
LCD display - monochrome - Yes
Body Colour
Charcoal black
Conference phone
Body Colour
Charcoal black
Phone Features
Call Services
Caller ID Type
Caller ID
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Menu Operation
Function Buttons
Conference button, menu navigation keys, mute button, hold button
Volume Control
Ringer Control
Indicators
Visual ringer light
Additional Functions
Built-in clock, call recording
Additional Features
Built-in SD card slot
Conference Phone
Package Content
OmniSound 2.0
Phone Memory
Phone Directory Capacity
50 names & numbers
Display
Display Location
Base
Display Resolution
128 x 64 pixels
Backlit
Display Languages
Danish, English, German, French, Italian, Norwegian, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish
Supported Flash Memory Cards
SD Memory Card
PSTN line jack , 2 x microphone jack
Placing / Mounting
Wall-mountable, table-top
Power adapter
Power adapter - external
Dimensions & Weight (Base)
24 cm
24 cm
7.7 cm
1 kg
