Your basket is empty
Audiocodes MediaPack Series MP-114 - VoIP gateway
Quicklinx: CC9QWS00 Mfr#: MP114/4S/SIP
The MediaPack Series Analog VoIP Gateways are cost-effective, best-of-breed technology products. These stand-alone analog VoIP Gateways provide superior voice technology for connecting legacy telephones, fax machines and PBX systems with IP-based telephony networks, as well as for integration with IP-based PBX systems. These products are designed and tested to be fully interoperable with leading Softswitches, SIP servers and H. 323 gatekeepers.
MediaPacks are well suited for commercial VoIP deployment because of their mature and field-proven voice and fax technology. Their rich feature set allows integration with a wide range of Carriers and Enterprise network applications. MediaPack gateways are used by carriers and service providers in access networks for connecting Multi-Tenant Units (MTU), IP Centrex subscribers, payphones and rural users over various wireless and satellite links. Enterprises use MediaPack gateways to connect their legacy PBX systems over an IP infrastructure. In addition, in IP Centrex and central IP-PBX applications, the MediaPack increases the remote location availability and provides Stand Alone Survivability (SAS) when there is no IP connection between branch locations and the central SIP servers, SIP Proxy or central IP-PBX.
MediaPacks are third generation products that have been designed to meet real market needs. In addition to superior voice technology, the products provide advanced telephony features such as long-haul, metering tones generation, country dependent MWI and CID for true integration with the existing telephony infrastructure. A variety of management and provisioning tools, such as AudioCodes' EMS, embedded web server, Telnet and SNMP enable fast deployment and management of large and complex networks. MediaPacks are based on VolPerfect architecture, AudioCodes underlying, best-of-breed, core media gateway technology for all of its products.
AudioCodes MediaPack Series MP-114 - VoIP gateway
VoIP gateway
External
Ports Qty
4
Ethernet, Fast Ethernet
VoIP Protocols
H.323, MGCP, SIP
Telephony Interfaces
4 phone (FXS)
AC 120/230 V ( 50 - 60 Hz )
22 cm x 17.2 cm x 4.2 cm
VoIP gateway
22 cm
17.2 cm
4.2 cm
External
Ports Qty
4
Wired
Network / Transport Protocol
IPSec, PPPoE, BOOTP, DHCP
Remote Management Protocol
HTTP, HTTPS, TFTP
Status Indicators
Link activity, status
DHCP support, BOOTP support, Syslog support, manageable, Data prioritization (Qos) for VoIP applications
Encryption Algorithm
TLS
IEEE 802.1Q, IEEE 802.1p
IP Telephony
VoIP Protocols
H.323, MGCP, SIP
Voice Codecs
G.711, G.723.1, G.729a, G.726, T.38
4 phone (FXS)
IP Telephony Features
Comfort noise generation (CNG), voice activity detection (VAD), echo cancellation (G.168), adaptative jitter buffer, automatic fax/modem detection and pass-through
1 x 100Base-TX - RJ-45 , 4 x modem - RJ-11 , 1 x management
1 x serial cable
VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, UL 60950-1, EN 60950-1
Internal power supply
5 °C
10 - 90%
