The Atlona HDMI 4 by 1 switcher has a high speed digital performance connection between four sources and a video display without signal degradation.
Bi-directional HDMI Ethernet channel
Use a single connection from your router to pass Internet by HDMI cable to all your HEC capable devices. -
Audio return channel
Allows for onboard TV tuners to stream audio to your A/V receiver through a single HDMI cable. -
Picture perfect quality
It is supporting pass through of all video resolutions between 480i and 1080p as well as 640 x 480 up to 1920 x 1200 for the high quality of video capable from sources.
- Atlona AT-HD4-V41 - video/audio switch - 4 ports
- Video/audio switch - 4 ports
- Subtype
- HDMI
- Ports
- 4 x HDMI
- Performance
- Bandwidth: 6.75 Gbps
- HDCP compliant, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), 3D support
- 24 cm x 11 cm x 5 cm
- 810 g
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- 4 x HDMI
- Performance
- Max Resolution
- 1920 x 1200 / 1080p
- Status Indicators
- Power, status
- 4 x HDMI input , 1 x HDMI output , 1 x serial (RS-232) DB-9 management , 1 x SPDIF output RCA , Remote control: 1 x IR - mini-phone stereo 3.5 mm , 1 x 10Base-T/100Base-TX - RJ-45
- Power Device
- External power adapter
- 4.1 Watt
- Included Accessories
- Remote control, IR receiver
- VESA EDID
- 24 cm
- 11 cm
- 5 cm
- 810 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
