The CS1708A KVM allows access to 8directly connected computers, and through Daisy chain architecture as many as 256total servers may be controlled from a single keyboard, mouse and monitor. To simplify installation and to keep track of so many servers a custom ASIC (patent pending) provides an auto-sensing function that recognizes the position of each KVM station in the chain. A front panel USB port provides server access to USB devices such as Hard Drives, or CDROM s, eliminating the need to physically connect a storage device to a server to install patches or updates.
- ATEN Master View max CS-1708A - KVM switch - 8 ports
- KVM switch - 8 ports - stackable
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Users Qty
- 1 local user
- 43.2 cm x 16 cm x 4.3 cm
- 1.5 kg
- 3 years warranty
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Max Resolution
- 2048 x 1536 @ 60 Hz
- Built-in Devices
- Led panel
- 8 x KVM DB-15 , 1 x network stack device input DB-25 , 1 x network stack device output DB-25 , 1 x KVM , 1 x RJ-11 management
- Power Device
- External power adapter
- 5 Watt
- DDC-2B
- 43.2 cm
- 16 cm
- 4.3 cm
- 1.5 kg
- 3 years warranty
