High definition real-time multimedia transcoding - Exceptional streaming capabilities
• Equipped with the latest Intel processor designed specifically for multimedia use
• 1080P high-definition multimedia playback capability
• The world’s best digital music player
• A rich variety of features and add-on applications via App Central
• A perfect union of hardware and software
• Use Searchlight to find any files, folders or functions you need
NAS real-time transcoding
The Intel CPU’s real-time hardware transcoding allows video files that are not supported by the playback device to be first converted into a playable format before being sent to the playback device. With such powerful hardware, even the real-time transcoding of 1080p high resolution video files is a piece of cake.
If bandwidth issues cause playback to become choppy, you can always adjust the resolution of the video stream to create a smoother playback experience.
Create the Ultimate Home Multimedia Center
Enjoy electrifying digital entertainment on demand with ASUSTOR NAS. The built-in HDMI interface and variety of multimedia Apps let you to enjoy all of your favorite multimedia from your NAS by directly connecting it to an LCD/LED TV or amplifier.
ASUSTOR NAS supports Full HD (1080p) output, allowing you to savor your movies, TV shows, music and photos in high definition. What's more, through ASUSTOR's App Central, you can install additional multimedia server Apps such as UPnP Media Server and iTunes Server giving your NAS the ability to stream multimedia content to your computers, TVs and mobile devices.
Cloud Access On The Go
ASUSTOR's dedicated mobile apps for iOS and Android allow you to get easy access to your NAS while you are out and about.
AiMaster
AiMaster is dedicated NAS management software for your mobile device. No matter if you are an individual user or IT administrator, AiMaster lets you conveniently manage your NAS while its comprehensive support for push notifications ensures that you stay up to date with the status of your system.
AiData
AiData lets you safely browse and access all the files stored on your NAS from your mobile device. Additionally, it allows you to stream multimedia content and view photos from your NAS as well as providing integration with Dropbox, Google Drive, Box.com that gives you easy data management across the cloud.
AiDownload
Use your mobile device to control Download Center on your ASUSTOR NAS. Whether it's searching, downloading or managing tasks, AiDownload gets it done in the blink of an eye. Furthermore, when your downloads are completed, your mobile device will receive immediate notification.
Your Ideal Private Cloud
Worried about how safe the data that you have put in public cloud storage is?
You can now use ASUSTOR NAS devices to effortlessly create a private cloud storage space for yourself. Using our exclusive Cloud Connect™ technology, you can access the data on your NAS device from almost anywhere on the planet. Whether by computer or mobile device, you need only an internet connection to access your NAS device from anywhere and at any time.
- ASUSTOR AS-302T - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- 10.8 cm x 23 cm x 16.35 cm
- 1.87 kg ()
- Processor
- 1 x Intel Atom 1.6 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
- Networking
- Network adapter 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 4
- RAM
- 1 GB
- Power
- AC 120/230 V
- System Requirements
- UNIX, Linux, FreeBSD, Microsoft Windows Server 2003, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 10.8 cm
- 23 cm
- 16.35 cm
- 1.87 kg ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 1 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap - 2.5" / 3.5" shared
- Network adapter
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- TCP/IP, PPTP, iSCSI, FTP, SMB, DDNS
- Remote Management Protocol
- HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Firewall protection, VPN support, VLAN support, wake on LAN (WOL), E-mail alert, IPv6 support, download client, event log, SSH support, iTunes server, Jumbo Frames support, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, IPv4 support, surveillance station, cloud backup
- Encryption Algorithm
- SSL, TLS, 256-bit AES
- UPnP
Security DVR
- 4
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x audio out - mini-jack , 1 x HDMI output
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), built-in cooling fan
- VCCI, C-Tick, BSMI, FCC, AES-256
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 19.9 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 24.3 dBA
