Asus ZenScreen MB16AC 15.6" 1920 x 1080 USB C Portable Monitor
Quicklinx: CW34WS00 Mfr#: MB16AC
Diagonal Size: 15.6in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: USB-C
£202.22 ex VAT
£242.66 inc VAT
ASUS ZenScreen MB16AC 15.6 inch FHD IPS USB Type-C Portable Eye Care Monitor
  • 15.6" FHD IPS USB Type-C portable monitor with hybrid signal solution for compatibility with USB Type-C and Type-A sources (Note: DisplayLink driver needed for Type-A connection)
  • Ultra-portable award-winning design at 1.7 pounds and 0.3 inches slim to pair perfectly with ASUS laptops
  • Smart cover and smart pen hole allow for landscape and portrait orientations easily with auto rotation
  • ASUS Eye Care technology with TUV Rheinland-certified flicker-free backlighting and blue light filter minimizes eye fatigue
  • Easily toggle through advanced display settings with the intuitive ASUS DisplayWidget
ASUS ZenScreen MB16AC - LED monitor - Full HD (1080p) - 15.6"
LED-backlit LCD monitor - 15.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.179 mm
Brightness
220 cd/m²
Contrast Ratio
800:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
262,000 colours
Input Connectors
USB
Dark grey
35.97 cm x 0.8 cm x 22.64 cm
780 g
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, UkrSEPRO, RCM, CU-EAC, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
Display Type
Diagonal Size
15.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.179 mm
Brightness
220 cd/m²
Contrast Ratio
800:1 (dynamic)
Colour Support
262,000 colours
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Glare, ASUS Splendid Video Preset Mode, 45% NTSC colour gamut, ASUS QuickFit Virtual Scale, ASUS GamePlus, Slim Design, Low Blue Light Mode, auto-rotation, Blue Light Filter technology
Dark grey
780 g
USB-C
Flicker-free technology
Carrying case with display stand
1 x USB-C cable , 1 x USB-C to USB-A adapter
8 Watt
Power Consumption (Off Mode)
0 Watt
Microsoft Windows 7 / 8.1 / 10
Shipping Width
42.4 cm
Shipping Depth
7.6 cm
Shipping Height
31 cm
Shipping Weight
3 kg
ENERGY STAR Certified
Asus ZenScreen MB16AC 15.6 Bundle deal on Asus ZenScreen MB16AC 15.6" 1920 x 1080 USB C Portable Monitor
£301.39
CW34 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £112.28
CW34 StarTech.com Articulating Monitor Arm In Stock £104.51
CW34 StarTech.com Dual Monitor Stand In Stock £70.92
CW34 StarTech.com Cubicle Monitor Hanger In Stock £45.76
Response Time: 5ms
Speakers: None
Interfaces: USB-C
Brand: Asus
Price Range Ex VAT: 150 - 300
