Asus ZenFone 4 Max 32GB 4G LTE GSM 5.5" dual-SIM - Rose Pink
Quicklinx: DMV8WS00 Mfr#: ZC554KL-4I085WW
Colours:
  • microSDHC
  • Android
120° Wide View Dual Rear Cameras, 5000mAh Battery
ASUS ZenFone 4 Max is a smartphone designed to go the distance and accompany you on all of life’s adventures. Its high capacity 5000mAh battery with advanced power management and dual cameras keeps up with your active lifestyle and is always at the ready to capture extraordinary moments.
Dual Rear Cameras - See a bigger world
ZenFone 4 Max features an advanced dual-camera system designed to take your mobile photography to new heights. Its 13MP main camera is equipped with the wide, F2.0 aperture lens to capture clearer photos. Its 120° wide-angle camera lets your fit more scenery and people in the frame for dramatic landscape shots, better group photos, and a more convenient photography experience in confined indoor spaces.
Wide-Angle Camera - Fit more scenery and friends in the shot
The 120° wide-angle camera on ZenFone 4 Max has a 200% larger field of view than standard smartphone cameras, so you can fit more scenery and people in the frame for dramatic photos and videos that capture a true sense of place. When taking photos indoors, the wide-angle view makes it much easier to get the shot you want — especially in confined spaces where it may not be possible to take a few steps back to fit everyone and everything into the photo. The unique perspective of the wide-angle lens can also be used to stylistic effect, allowing you to exaggerate the sense of space in any setting to capture more dramatic scenes and stunning, expansive landscapes.
PixelMaster Camera - Capture your world in detail
ZenFone 4 Max comes with a 13MP PixelMaster rear camera to capture beautiful, high-resolution photos with zero shutter lag. An 8MP front camera takes gorgeous, sharp selfies and lets you enjoy video chatting in with crystal-clear video clarity.
Front Camera - Capture the perfect selfie
ZenFone 4 Max combines an 8MP front camera with a Softlight LED flash and live beautification features to capture stunning selfies with ease. The Softlight LED flash delivers the perfect amount of fill light, giving your selfies a softer look with true skin tones and a glowing complexion. Beauty mode instantly retouches your selfies, removing blemishes, balancing facial features, and more to create a flawless look.
Beauty Mode - More beautiful, more fun, more you
The fun and intuitive Beauty mode lets you apply a variety of enhancement effects to your selfies to make them even more glamorous. With ten levels of beautification to choose from, you can smooth wrinkles, remove blemishes, adjust skin tone, and enhance your features instantly. Whether you are taking photos, capturing a video, or live streaming, ZenFone 4 Max lets you create your perfect look for the camera.
ASUS PowerMaster™ - A smarter smartphone battery
ZenFone 4 Max features a suite of intelligent power management technologies that work in concert to optimize battery life, ensure safety and long-term performance, provide reverse-charging capability, and more. By turning on the double battery lifespan feature, it means your device can fully charge (to 100%) and discharge (to 0%) up to 500 times in a 25°C environment, and the loss of battery capacity will be reduced by half.
  • This feature "double battery lifespan" effectiveness may vary depending on your usage.
High capacity, 5000mAh battery
Inside the sleek exterior of ZenFone 4 Max lies massive energy — a 5000mAh battery custom-crafted to pack maximum performance into minimum space. With so much power at your disposal, you can do more online, stream longer videos, and talk as much as you want without worry of getting through the day.
  • Standby time measured by current meter with typical battery capacity. Results may vary depending on different test conditions.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
  • Dual rear cameras
  • Wide-angle camera
    The 120° wide-angle camera on ZenFone 4 Max has a 200% larger field of view than standard smartphone cameras, so you can fit more scenery and people in the frame for dramatic photos and videos that capture a true sense of place. When taking photos indoors, the wide-angle view makes it much easier to get the shot you want - especially in confined spaces where it may not be possible to take a few steps back to fit everyone and everything into the photo. The unique perspective of the wide-angle lens can also be used to stylistic effect, allowing you to exaggerate the sense of space in any setting to capture more dramatic scenes and stunning, expansive landscapes.
  • PixelMaster camera
  • Capture the perfect selfie
  • Beauty mode
  • A smarter smartphone battery
  • High capacity, 5000mAh battery
    Inside the sleek exterior of ZenFone 4 Max lies massive energy - a 5000mAh battery custom-crafted to pack maximum performance into minimum space. With so much power at your disposal, you can do more online, stream longer videos, and talk as much as you want without worry of getting through the day.
  • Fast, multi-threaded performance
    ZenFone 4 Max features a powerful Qualcomm's Snapdragon processor. With its superb performance and superior power-efficiency you'll shoot sharp photographs at stupefying speed. Its fingerprint sensor is perfectly positioned for the way you hold your phone. It unlocks ZenFone 4 Max in a fraction of a second, and does so much more besides.
  • Dual SIM with individual microSD card slot
    ZenFone 4 Max comes with two SIM card slots supporting speeds up to 150Mbps and an additional microSD card slot to expand storage by up to 256GB. Its convenient triple-slot tray lets you install both SIMs and a microSD card in one easy step.
  • Android 7 with brand new ZenUI
    The latest version of ZenFone's beautiful user interface that's designed to provide a more intuitive experience to help you accomplish tasks and find information faster, improve your productivity, and simply have more fun using your phone.
ASUS ZenFone 4 Max (ZC554KL) - rose pink - 4G smartphone - 32 GB - GSM
4G smartphone
Manufacturer Model Number
ZC554KL
Display
LCD display - 1280 x 720 pixels - 5.5" - IPS
FM radio
Qualcomm Snapdragon 430 MSM8937 / 1.4 GHz (8-core) - 64-bit
Graphics Accelerator
Qualcomm ADRENO 505
RAM 3 GB / 32 GB
Supported Memory Card
microSDXC slot - up to 256 GB
Operating System
Android 7.1.1 Nougat with ASUS ZenUI
Main Camera
13 Megapixel - f/2.0 - focus: automatic laser auto focus: - laser focus
Second Camera
5 Megapixel - wide-angle lens
Front Camera
8 Megapixel - wide-angle lens - f/2.2
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
Wi-Fi, Bluetooth
Security Devices
Fingerprint reader
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, Micro-USB
Talk Time
Up to 2400 minutes
Standby Time
Up to 1104 hours
Rose pink
76.9 mm x 8.9 mm x 154 mm
181 g
0.302 W/kg (head) , 1.2 W/kg (body)
Smartphone
ZC554KL
Touch
Integrated Components
FM radio
76.9 mm
8.9 mm
154 mm
181 g
Body Colour
Rose pink
Body Material
Metal
SAR Value
1.2 W/kg (body), 0.302 W/kg (head)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
User Interface
ASUS ZenUI
Navigation
GPS, A-GPS, GLONASS, BeiDou
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE, FDD-LTE, TDD-LTE
2G Band
850 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 5, Band 8
3G UMTS Frequency
2100, 850, 900
4G LTE Band
Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 40
4G LTE Frequency
FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, TDD 2300
Wireless Interface
IEEE 802.11b/g/n, Bluetooth 4.1
Phone Features
Phone Functions
Speakerphone, call timer, conference call, flight mode, vibrating alert
Sensors
Ambient light sensor, proximity sensor, digital compass, gyro sensor, G-sensor
Security Devices
Fingerprint reader
Additional Features
Dual microphones, Google Drive Storage (100 GB) (free for 2 years), power bank function, ASUS PowerMaster
Processor Number
MSM8937
Clock Speed
1.4 GHz
Processor Core Qty
8-core
64-bit Architecture
Graphics System
Qualcomm ADRENO 505
RAM
LPDDR3 SDRAM - 3 GB
Internal Memory Capacity
32 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 256 GB
Front Camera
Sensor Resolution
8 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/2.2
Light Source
LED light
Main Camera
Sensor Resolution
13 Megapixel
Lens Aperture
F/2.0
Focus Adjustment
Automatic
Laser Auto Focus
Camera Modes
Panorama, Pro mode
Light Source
LED light
Video Resolutions
1920 x 1080 (1080p) at 30 fps
Phase Detect Auto-Focus (PDAF), Electronic Image Stabiliser (EIS), PixelMaster 4.0 camera, Instant cameras switching
Second Camera
Sensor Resolution
5 Megapixel
Lens Type
Wide-angle lens
Display
LCD display
IPS
Diagonal Size
5.5"
Display Resolution
1280 x 720 pixels
Display Format
HD
Colour Depth
16.7 million colours
Enhancement Technology
Blue light filter
2.5D curved glass
Connector Type
Headset jack - mini-phone 3.5mm , Micro-USB - 5 pin Micro-USB Type B
Lithium polymer
5000 mAh
Talk Time
2400 minutes
Standby Time
1104 hours
Run Time Details
Talk: up to 2400 min , Standby: up to 1104 hrs , Playback (video): up to 22 hrs , Active online usage (Wi-Fi): up to 26 hrs
Headset, power adapter, OTG cable, micro-USB to USB cable
