Asus Zenbook UX433FA Core i7-8565 8GB 512GB 14" Windows 10 Home - Royal Blue
Quicklinx: DZSSWS00 Mfr#: UX433FA-A5128T
Display Size: 14in
Processor Model: I7-8565U
Operating System: Windows 10 Home
Installed Memory: 8GB
Hard Drive Capacity: 512GB
  • Core i7
14 left in stock
£707.50 ex VAT
£849.00 inc VAT
Express delivery Order within the next 11 hours for delivery tomorrow
Unleash your creative vision
The world’s smallest 14-inch laptop
Creativity. Style. Innovation. These are the qualities that define the elegant new ZenBook 14. Everything in this take-anywhere masterpiece — it’s the world’s smallest 14-inch laptops* — is designed to give you the freedom to discover your creative power, including its breathtaking frameless NanoEdge display. You’ll appreciate not only the tremendous power within and the thoughtful attention to detail — such as the exclusive ErgoLift hinge and NumberPad touchpad — but also the timeless beauty of the design, with its sensational Royal Blue or Icicle Silver finish enhanced by the new Rose Gold trim panel. ZenBook 14 is waiting: are you ready to unleash your creative power?
The most compact design ever
ZenBook 14 heralds a new era of ultraportable design, with an ultracompact, ultralight chassis. Featuring the 4-sided NanoEdge display, the ZenBook 14 is one of the world’s most smallest 14-inch laptop and is 13% smaller than the previous generation ZenBook 14 (UX430).
NanoEdge Display
Designed to give you the most screen area in the least physical space, the new frameless four-sided NanoEdge design of ZenBook 14 is simply breathtaking: it makes any visuals more immersive, with less distraction for your eyes. The ultraslim bezels1 are just 2.9mm thin at the sides, 3.3mm at the bottom and a mere 6.1mm at the top to accommodate the camera. The effect is truly stunning — it’s like an infinity pool for your eyes! And with this ultra-compact display, ZenBook 14 is only about the size of an A4 sheets — smaller than many 13.3-inch laptops.
Spectacular visuals
Creativity demands a great screen, so ZenBook 14 has a crisp, clear, high-resolution display that makes any visuals look their best, with wide viewing angles and vivid, accurate colours. It also features exclusive ASUS technologies — including ASUS Splendid and ASUS Tru2Life Video — that fine-tune display parameters to ensure optimum eye comfort and colour performance, for any kind of content.
Designed with you in mind
With any ZenBook, your comfort is one of our top priorities. ZenBook 14 goes the extra mile with its exclusive ErgoLift hinge, an engineering masterpiece designed to automatically tilt the keyboard to the most comfortable typing position. But that’s not all: the carefully calculated tilt improves cooling and audio performance, too.
Extraordinary elegance
None of the traditional ZenBook style has been lost, though: there’s the iconic Zen-inspired spun-metal finish on the lid and a choice of prestigious Royal Blue or sophisticated Icicle Silver finishes, both newly enhanced with a contrasting Rose Gold trim panel above the keyboard for an extra touch of luxury. The elegant Royal Blue colour is inspired by the awesome beauty of a golden sunrise over the deep-blue ocean. The sophisticated Icicle Silver reflects the stunning contrasts of native gold and moonlight silver, a harmonious pairing celebrated in this classic theme.
Unbounded performance
Designed to empower your creativity, ZenBook 14 doesn’t sacrifice performance for size. It’s built to give you all the raw power you need for effortless on-the-go computing. Featuring the latest Intel® Core™ processors and packed with high-quality, high-performance components, ZenBook 14 will never keep you waiting. Whether you’re creating complex documents, mining data, retouching photos, editing videos, or simply taking a gaming break, ZenBook 14 lets you do more — and do it quicker.
  • Compact design
    ZenBook 14 heralds an era of portable design, with an ultra-compact, ultra-light chassis. Featuring the 4-sided NanoEdge display, the ZenBook 14 is extremely sleek.
  • Unbounded beauty
    Designed to give you more screen area in less physical space, the frameless four-sided NanoEdge design of ZenBook 14 is simply breathtaking: it makes any visuals more immersive, with less distraction for your eyes.
  • Spectacular visuals
    Creativity demands a great screen, so ZenBook 14 has a crisp, clear, high-resolution display that makes any visuals look their best, with wide viewing angles and vivid, accurate colors.
  • Designed with you in mind
    With any ZenBook, your comfort is a high priority ZenBook 14 goes the extra mile with its exclusive hinge, an engineering masterpiece designed to automatically tilt the keyboard to a comfortable typing position. But that's not all: the carefully calculated tilt improves cooling and audio performance, too.
  • Mobility without bounds
    As a mobile professional, you need to stay connected. ZenBook 14 is equipped with Wi-Fi, so you can enjoy fast downloads and smooth streaming with greater range and more stable network connections.
  • All-day battery for non-stop lifestyles
    ZenBook 14 is powered by a high-capacity battery that won't let you down, however long and demanding your working day is. Extended journeys or day-long meetings are no problem for ZenBook 14, even when power outlets are in short supply.
ASUS ZenBook 14 UX433FA A5128T - 14" - Core i7 8565U - 8 GB RAM - 512 GB SSD
Notebook
Operating System
Windows 10 Home
Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
512 GB - M.2 SSD NVMe
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
NumberPad
Keyboard Backlight
Integrated Webcam
802.11ac, Bluetooth 5.0
3-cell
Royal blue
31.9 cm x 19.9 cm x 1.59 cm
1.19 kg
Notebook
Operating System
Windows 10 Home
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Storage
Main Storage
512 GB SSD - (M.2) PCIe - NVM Express (NVMe)
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Ultra Slim Design, ASUS Splendid Video Intelligence Technology, anti-glare, 178° horizontal and vertical viewing angle, NanoEdge display
Audio & Video
Graphics Processor
Camera
Yes - HD
Camera Features
IR/RGB camera
Sound
Harman/kardon stereo speakers, array microphone
Input
Keyboard, NumberPad
Keyboard Backlight
Communications
Wireless
3-cell lithium polymer
50 Wh
AC Adapter
Input
Output
65 Watt, 19 V
Connections & Expansion
Headphone/microphone combo jack , USB-C 3.1 Gen 2 , USB 3.1 Gen 1 , HDMI , USB 2.0
Memory Card Reader
Yes (microSD)
Royal blue
Power adapter
1.19 kg
Software applications
Asus Zenbook UX433FA Core i7-8565 8GB 512GB 14 Bundle deal on Asus Zenbook UX433FA Core i7-8565 8GB 512GB 14" Windows 10 Home - Royal Blue
£887.08
saving £2.42
£806.67
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Asus
Stock Status: Clearance
Price Range Ex VAT: 500 - 750
