Asus Zenbook UX433 Core i7-8565 16GB 512GB SSD 14" Windows 10 Pro
Quicklinx: F30TWS00 Mfr#: ZENBOOK14-33FA-A5179R
Display Size: 14in
Processor Model: I7-8565U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 512GB
  • Core i7
£998.01 ex VAT
£1,197.61 inc VAT
Creativity. Style. Innovation. These are the qualities that define the elegant ZenBook 14. Everything in this take-anywhere masterpiece is designed to give you the freedom to discover your creative power, including its breathtaking frameless NanoEdge display. You'll appreciate not only the tremendous power within and the thoughtful attention to detail but also the timeless beauty of the design.
  • Compact design
    ZenBook 14 heralds an era of portable design, with an ultra-compact, ultra-light chassis. Featuring the 4-sided NanoEdge display, the ZenBook 14 is extremely sleek.
  • Unbounded beauty
    Designed to give you more screen area in less physical space, the frameless four-sided NanoEdge design of ZenBook 14 is simply breathtaking: it makes any visuals more immersive, with less distraction for your eyes.
  • Spectacular visuals
    Creativity demands a great screen, so ZenBook 14 has a crisp, clear, high-resolution display that makes any visuals look their best, with wide viewing angles and vivid, accurate colors.
  • Designed with you in mind
    With any ZenBook, your comfort is a high priority ZenBook 14 goes the extra mile with its exclusive hinge, an engineering masterpiece designed to automatically tilt the keyboard to a comfortable typing position. But that's not all: the carefully calculated tilt improves cooling and audio performance, too.
  • Mobility without bounds
    As a mobile professional, you need to stay connected. ZenBook 14 is equipped with Wi-Fi, so you can enjoy fast downloads and smooth streaming with greater range and more stable network connections.
  • All-day battery for non-stop lifestyles
    ZenBook 14 is powered by a high-capacity battery that won't let you down, however long and demanding your working day is. Extended journeys or day-long meetings are no problem for ZenBook 14, even when power outlets are in short supply.
ASUS ZenBook 14 UX433FA A5179R - 14" - Core i7 8565U - 16 GB RAM - 512 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache
16 GB LPDDR3 (provided memory is soldered)
Storage
512 GB - M.2 SSD NVMe
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11ac, Bluetooth 5.0, Ethernet
3-cell
Security
Firmware Trusted Platform Module (TPM) Security Chip
Royal blue metal
31.9 cm x 19.9 cm x 1.59 cm
1.09 kg
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
16 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
2133 MHz
Storage
Main Storage
512 GB SSD - (M.2) PCIe - NVM Express (NVMe)
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Ultra Slim Design, ASUS Splendid Video Intelligence Technology, anti-glare, 72% NTSC colour gamut, 178° horizontal and vertical viewing angle, NanoEdge display
Audio & Video
Graphics Processor
Camera
Yes - HD
Camera Features
IR/RGB camera
Sound
Harman/kardon stereo speakers, array microphone
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Network Interface
Ethernet
3-cell Lithium Ion
50 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Headphone/microphone combo jack , USB-C 3.1 Gen 2 , USB 3.1 Gen 1 , HDMI , USB 2.0 , LAN (on supplied cable)
Memory Card Reader
Yes (microSD)
Royal blue metal
Security
ErgoLift
Power adapter, sleeve, USB 3.0 to Ethernet adapter
1.09 kg
Software applications
Asus Zenbook UX433 Core i7-8565 16GB 512GB SSD 14 Bundle deal on Asus Zenbook UX433 Core i7-8565 16GB 512GB SSD 14" Windows 10 Pro
£1,183.23
saving £8.33
£1,097.18
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Type: Laptop
Brand: Asus
Price Range Ex VAT: 750 - 1000
