Asus Zenbook UX430UA-GV415T Core i7-8550 8GB 256GB SSD Windows 10
Quicklinx: DTVTWS00 Mfr#: UX430UA-GV415T
  • Core i7
  • IEEE 802.11n
ASUS ZenBook UX430UA with Intel® Core™ i7 Processor.
8th Gen Intel® Core™ processors: Designed for what's coming next.
ZenBook has always been a different kind of ultraportable laptop, but the elegant and sophisticated ZenBook UX430 is a new kind of different: we’ve crafted a travel-friendly 13-inch ZenBook with a work-friendly 14-inch display! For the first time ever, you don’t have to make the difficult choice between portability and screen size — the incredible ZenBook UX430 achieves the impossible by delivering both! Its slim and lightweight design, iconic ZenBook styling, and high-performance components make ZenBook UX430 the take-anywhere powerhouse you won’t want to leave behind, wherever you go. Take more with you, in less space!
13-inch Chassis
Lighten your load
ZenBook UX430 is designed to go wherever your busy lifestyle takes you — whether it’s a hectic round of meetings, a crammed international schedule, or a well-deserved vacation. Its sleek and compact 13-inch chassis is a briefcase-friendly 15.9mm thick, and its advanced lightweight construction keeps the weight down to just 1.25 kg — so it’ll never be a burden when you’re on the go.
  • 15.9mm thin
  • 1.25kg light
  • 13"size compact design
NanoEdge Display
See more, do more!
When it comes to getting things done, everyone agrees that a bigger display is a better display, because it makes multitasking easier and entertainment more immersive. That’s why we’ve broken all the rules to give ZenBook UX430 the biggest screen possible: The stunning 14-inch Full HD NanoEdge display has an ultra-narrow 7.18mm bezel that allows it to fit into a svelte 13-inch chassis. To maximise your viewing comfort, the NanoEdge display also has a matte anti-glare coating that reduces annoying reflections. The result is a laptop with an impressive 80% screen-to-body ratio* that minimises size while helping you maximise productivity — so you can see and do more, while carrying less!
  • Calculated using the visible body area.
Viewing perfection
The ZenBook series is renowned for superb display quality, and ZenBook UX430 is no exception. Its 14-inch anti-glare display has an ultra-wide 100% sRGB colour gamut, which means it can display more-accurate and more-vivid colours than a standard display. It also uses wide-view technology to ensure that contrast and colour reproduction are not degraded at viewing angles up to 178° degrees, making it perfect for collaboration and screen sharing.
All-day battery for non-stop lifestyles
Designed for non-stop, on-the-go lifestyles, ZenBook UX430 offers the freedom of all-day battery life. A special 50Wh lithium-polymer battery gives ZenBook UX430 up to 9 hours of autonomy. Lithium-polymer batteries retain most of their original charge capacity even after hundreds of charge cycles — up to 3x longer than standard batteries — so you don't have to worry about deteriorating battery performance.
Every connection you need
ZenBook UX430 is equipped with the new, reversible USB Type-C™ (USB-C™) port that offers an any-way-up design to make connecting devices as easy as possible. It also delivers data transfer speeds that are up to 10x faster than older USB 2.0 connections! Along with the USB-C port, there’s a USB 3.1 Gen 1, a Micro HDMI, and an SD card slot — so you can easily connect all your current peripherals, displays and projectors with zero hassle.
  • See more, do more
    When it comes to getting things done, everyone agrees that a bigger display is a better display, because it makes multitasking easier and entertainment more immersive. That's why the ZenBook UX430 has a big screen. With a reduced bezel, it has a stunning display into a svelte chassis. To maximize your viewing comfort, the display also has a matte anti-glare coating that reduces annoying reflections.
  • Viewing perfection
    The ZenBook series has superb display quality, and the ZenBook UX430 is no exception. Its anti-glare display has an ultra-wide color gamut, which means it can display more accurate and more vivid colors. It also uses wide-view technology to ensure that contrast and color reproduction are not degraded at wider viewing angles, making it perfect for collaboration and screen sharing.
  • Timeless elegance
    Elegance, sophistication and style are the hallmarks of the ZenBook series. The exquisite ZenBook UX430 continues that tradition, combining precision craftsmanship and premium materials to give you a laptop that stands out from the crowd. The Zen-inspired, concentric-circle design is enhanced with a stunning crystal-like coating that's created using an advanced technique known as nano-imprinting lithography.
  • All-day battery
    Designed for non-stop, on-the-go lifestyles, the ZenBook UX430 offers the freedom of all-day battery life. A special battery gives the ZenBook UX430 several hours of autonomy.
  • Every connection you need
    The ZenBook UX430 is equipped with the reversible USB Type-C port that offers an any-way-up design to make connecting devices as easy as possible. It also delivers fast data transfer speeds. Along with the USB-C port, there's a USB 3.1 and an SD card slot - so you can easily connect all your peripherals, displays and projectors with zero hassle.
  • Sound that will amaze you
    A tailored mix of superior hardware - including smart amplifier technology that delivers louder sound with no distortion - and cleverly designed software ensure that the ZenBook UX430 gives you an incredible audio experience.
ASUS Zenbook UX430UA GV415T - 14" - Intel Core i7 - 8550U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i7 (8th Gen) - 8550U / 1.8 GHz, up to 4 GHz
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Ethernet
3-cell
Security
Firmware Trusted Platform Module (TPM) Security Chip, fingerprint reader
Blue NIL with spin hairline (LCD cover), blue metal with sand blast (top)
32.4 cm x 22.5 cm x 1.59 cm
1.25 kg
0.603 W/kg (body) , 0.603 W/kg (limb)
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (8th Gen) 8550U / 1.8 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Rated Speed
1866 MHz
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Colour Gamut
100% sRGB
ASUS Splendid Video Intelligence Technology, anti-glare, WideView, ASUS EyeCare Technology, 178° horizontal and vertical viewing angle, Tru2Life
Audio & Video
Graphics Processor
Camera
Yes - HD
Camera Features
Windows Hello
Sound
Harman/kardon stereo speakers, array microphone
Audio Features
Output: ASUS SonicMaster
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Network Interface
Ethernet
3-cell Lithium Ion
50 Wh
AC Adapter
Input
Output
65 Watt, 19 V, 2.37 A
Connections & Expansion
Interfaces Details
USB 2.0 , Micro-HDMI , USB 3.1 Gen 1 , Headphone/microphone combo jack , USB-C 3.1 Gen 1 , LAN (on supplied cable) , HDMI (on supplied cable)
Memory Card Reader
Yes (SD Card, MultiMediaCard)
Security
System password, hard drive password
Power adapter
Micro-HDMI-HDMI cable , USB 3.0 Type A to LAN adapter
SAR Value
0.603 W/kg (body), 0.603 W/kg (limb)
1.25 kg
Sustainability Information
TCO Certified
