Asus Zenbook UX410UA i7-8550U 8GB 256GB M.2 SSD 14" Win 10 Pro
Quicklinx: DVM8WS00 Mfr#: UX410UA-GV334R-OSS
Display Size: 14in
Processor Model: I7-8550U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i7
£854.36 ex VAT
£1,025.23 inc VAT
Marketing description is not available.
  • Incredible performance
    Superb mobile performance is the hallmark of ZenBook, and in ZenBook UX410 this is delivered by a powerful processor. The dual-band 802.11ac Wi-Fi provides super-fast speeds, and Bluetooth 4.1 connects you easily to your gadgets. The revolutionary, reversible USB Type-C port gives you high-speed access to high-performance peripherals. With the HDMI port, you can connect to monitors, TVs or projectors with no hassle. Effortless multitasking, smooth video playback, and super-fast application launches - ZenBook UX410 is always ready when you are. It's supremely energy-efficient too, meaning fewer trips to the power socket!
  • Clear display
    With ZenBook UX410, ASUS has achieved the impossible: fitting a stunning 14-inch up to Full HD display into a laptop that's no bigger than most 13-inch models. The secret is the ultraslim bezel, which not only allows ASUS to fit a larger screen, but also gives you distraction-free viewing whether you're reading text, viewing photos or watching videos. The amazing resolution makes photo or video editing so much easier, and the incredible pixel density of 276 pixels per inch makes every tiny detail pin-sharp and crystal-clear.
  • ASUS Splendid: superbly optimized color
    To ensure only the very best images, ZenBook UX410 incorporates ASUS Splendid technology to give you richer, deeper and more accurate colors. ASUS Splendid has four one-click preset modes: Normal mode, Eye Care mode, Vivid mode and Manual mode. Normal mode gives you the factory-optimized settings, Eye Care mode reduces blue light levels for comfortable viewing, and Vivid mode cleverly adjusts the display settings to give images a really vibrant and vivid appearance, without making the colors look artificial. Manual mode gives you control over the color temperature setting, so you can adjust the display to suit your own needs and preferences.
  • Ultra connectivity
    ZenBook UX410 is equipped with the reversible USB Type-C port with its any-way-up design that makes connecting devices so much easier. It also delivers data transfer speeds up to 10 times faster than USB 2.0 connections! In addition, ZenBook UX410 has a USB 3.0 port, a HDMI port and an SD card slot so you can easily connect your current peripherals, displays and projectors with zero hassle.
  • Outstandingly comfortable backlit keyboard
    ZenBook UX410's full-size backlit keyboard is sturdily constructed in a single piece for a superb typing experience. It's a masterpiece of ergonomics, with an optimized 1.6mm key travel for a comfortable feel. The gentle backlight ensures easy use in low-light conditions.
  • ASUS SonicMaster: designed to sound incredible
    Co-developed by the ASUS Golden Ear team and Harman Kardon, ASUS SonicMaster technology delivers incredible sound. A tailored mix of superior hardware and cleverly designed software ensures that ZenBook UX410 gives you the ultimate sound experience.
ASUS ZenBook UX410UA GV334R - 14" - Core i7 8550U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) 8550U / 1.8 GHz (4 GHz)
8 GB DDR4 (provided memory is soldered)
Storage
256 GB - M.2 SSD
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11ac, Bluetooth 4.2
3-cell
Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Quartz grey
32.3 cm x 22.3 cm x 1.895 cm
1.4 kg
Limited warranty - 3 years - on-site
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
Max RAM Supported
16 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
ASUS Splendid Video Intelligence Technology, anti-glare, 72% NTSC colour gamut, ASUS EyeCare Technology, 178° horizontal and vertical viewing angle
Audio & Video
Graphics Processor
Camera
Yes - HD
Sound
Stereo speakers, microphone
Audio Features
ASUS SonicMaster
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
3-cell lithium polymer
48 Wh
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
2 x USB 2.0 , HDMI , USB 3.1 Gen 1 , Headphone/microphone combo jack , USB-C 3.1 Gen 1 , LAN (on supplied adapter) , VGA (on supplied adapter)
Memory Card Reader
Yes (SD Card, SDHC Card)
Quartz grey
Security
System password
Power adapter, carrying case, USB to Ethernet adapter
HDMI-VGA adapter
1.4 kg
Software applications
Asus Zenbook UX410UA i7-8550U 8GB 256GB M.2 SSD 14 Bundle deal on Asus Zenbook UX410UA i7-8550U 8GB 256GB M.2 SSD 14" Win 10 Pro
£1,039.58
saving £8.33
£953.53
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Type: Laptop
Brand: Asus
Price Range Ex VAT: 750 - 1000
