Asus Zenbook UX410UA i5-8250U 8GB 256GB M.2 SSD 14"  Win 10 Pro
Quicklinx: DVM7WS00 Mfr#: UX410UA-GV296R-OSS
  • Core i5
Marketing description is not available.
  • Sleek and elegant
    Using solid aluminum alloy keeps the weight down, but it takes precisely controlled manufacturing steps to craft it into its sleek shape. The spun-metal finish, adorns the lid, with a tough and durable brushed metal finish adorning the rest of the chassis.
  • Incredible performance
    Superb mobile performance is the hallmark of the ZenBook UX410. This performance is delivered by a fast processor, with plenty of RAM for ultra-smooth video. True professionals demand great technology, and the reversible USB Type C port gives you high-speed access to high-performance peripherals. With the HDMI port, you can connect to monitors, TVs or projectors with no hassle. Effortless multitasking, smooth video playback, and super-fast application launches - the ZenBook UX410 is always ready when you are.
  • Protect your eyes with ASUS Eye Care
    Too much exposure to the blue light emitted by LCD displays is thought to affect eye health, and it can also cause fatigue during long viewing sessions. ASUS Eye Care reduces the emissions of blue light, so that your eyes are always protected.
  • Great connectivity
    The ZenBook UX410 is equipped with the reversible USB Type C port with its any-way-up design, that makes connecting devices so much easier. It also delivers fast data transfer speeds. In addition, the ZenBook UX410 has USB 3.0 ports, and an SD card slot, so you can easily connect your peripherals, displays and projectors with zero hassle.
  • Comfortable backlit keyboard
    The ZenBook UX410's full-size backlit keyboard is sturdily constructed in a single piece for a superb typing experience. It's a masterpiece of ergonomics, with an optimized key travel for a comfortable feel. The gentle backlight ensures easy use in low-light conditions.
  • Designed to sound incredible
    ASUS SonicMaster technology delivers incredible sound. A tailored mix of superior hardware ensures, that the ZenBook UX410 gives you an amazing sound experience.
ASUS ZenBook UX410UA GV296R - 14" - Core i5 8250U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11ac, Bluetooth 4.1
3-cell
Grey
32.3 cm x 22.3 cm x 1.895 cm
1.4 kg
SAR
0.389 W/kg (body), 0.389 W/kg (limb)
Limited warranty - 3 years - on-site
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
Max RAM Supported
16 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2)
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
ASUS Splendid Video Intelligence Technology, anti-glare, WideView, 72% NTSC colour gamut, ASUS EyeCare Technology
Audio & Video
Graphics Processor
Camera
Yes - HD
Sound
Stereo speakers, microphone
Audio Features
ASUS SonicMaster
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
3-cell Lithium Ion
48 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
2 x USB 2.0 , HDMI , USB 3.1 Gen 1 , Headphone/microphone combo jack , USB-C 3.1 Gen 1
Memory Card Reader
Yes (SD Card, SDHC Card)
Grey
System password, Intel Anti-Theft Technology (iAT)
Theft/Intrusion Protection
Power adapter
SAR Value
1.4 kg
