The ZenBook UX330 is simply breathtaking. Its supremely elegant aluminum unibody chassis is very thin and light. Its looks are impressive, with the stunning spun-metal finish. The ZenBook UX330 has more than enough performance to cope with all your on-the-go productivity needs.
Supremely thin
The ZenBook series in thin and light, featuring an elegant design. Using solid aluminum alloy, it keeps the weight down. -
Long battery life
The ZenBook UX330 is built for serious mobility, with a design that helps it last for several hours between charges. -
ASUS Splendid
To ensure you see only perfect images, the ZenBook UX330 incorporates ASUS Splendid technology to give you richer, deeper and more accurate colors. -
Protect your eyes with ASUS Eye Care
Too much exposure to the blue light emitted by LCD displays is thought to affect eye health, and it can also cause fatigue during long viewing sessions. ASUS Eye Care mode reduces the emissions of blue light. -
Comfortable backlit keyboard
The ZenBook UX330's full-size backlit keyboard is sturdily constructed in a single piece for a superb typing experience. It's a masterpiece of ergonomics. -
ASUS SonicMaster
ASUS SonicMaster technology delivers incredible sound. Superior hardware ensures that the ZenBook UX330 gives you an amazing sound experience.
- ASUS Zenbook UX330UA FC093T - 13.3" - Intel Core i5 - 7200U - 8 GB RAM - 512 GB SSD
- Product Type
- Notebook
- Operating System
- Windows 10 Home
- Processor
- Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB SSD
- Display
- 13.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- Up to 12 hours
- Quartz grey
- 32.3 cm x 22.23 cm x 1.35 cm
- 1.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Notebook
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 512 GB SSD M.2 SATA 6Gb/s
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Colour Gamut
- 72% NTSC
- ASUS Splendid Video Intelligence Technology, WideView, ASUS EyeCare Technology
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Image Sensor Type
- CMOS
- Sound
- Harman/kardon stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower
Input
- Keyboard, touchpad
Communications
- Wireless
- Intel Wireless Display (WiDi)
- Technology
- Lithium polymer
- Capacity
- 57 Wh
- Run Time
- Up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , 2 x USB 3.0 , Micro-HDMI , USB-C Gen 1
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Quartz grey
- Case Material
- Aluminum
- System password, ASUS USB Charger+
- Included Accessories
- Power adapter
- UL, TUV, BSMI, CCC, FCC
- 1.2 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
