The ZENBOOK UX310 brings you elegance, sophistication and superb performance in a gorgeously slim and light design. Crafted from solid aluminum and featuring spun-metal Zen-inspired finish, ZENBOOK UX310 is extremely thin. And its travel-friendly weight means taking it with you is never a burden, and using it is always a pleasure with its crisp, clear wide viewing angle display. Featuring a powerful processor, super-fast storage, ZENBOOK UX310 is no slouch, either - it has all the performance you need to blitz through your working day. ZENBOOK UX310 makes everything easier, in style.
Ultra-sleek and ultra-elegant
The ZENBOOK UX310 continues proud heritage, featuring a timelessly elegant design with a profile, that's extremely thin. The sleek spun-metal finish, with its Zen-inspired concentric circles, adorns the lid, with a tough and durable brushed-metal finish adorning the rest of the chassis. -
Incredible performance
Superb mobile performance is the hallmark of ZENBOOK, and in ZENBOOK UX310 this is delivered by a powerful processor, with large RAM for ultra-smooth video. The dual-band 802.11ac Wi-Fi provides super fast speeds, and Bluetooth connects you easily to your gadgets. The USB Type C port gives you high-speed access to the high-performance peripherals. With the HDMI port, you can connect to monitors, TVs or projectors with no hassle. Effortless multitasking, smooth video playback, and super-fast application launches - ZENBOOK UX310 is always ready, when you are. It's supremely energy-efficient too, meaning fewer trips to the power socket! -
More colors
ZENBOOK UX310's display features an ultra-wide color gamut of NTSC, sRGB, and AdobeRGB. In plain language, this means it can display more colors, more accurate colors and more vivid colors. And wide view angle technology ensures, that contrast and color reproduction are not degraded up to 178° degrees, ZENBOOK UX310 sets the standard for laptop displays. -
Ultra connectivity
ZENBOOK UX310 is equipped with the reversible USB Type C port with its any-way-up design, that makes connecting devices so much easier. It also delivers high data transfer speeds! In addition, ZENBOOK UX310 has USB 3.0 ports, an HDMI port and an SD card slot, so you can easily connect your current peripherals, displays and projectors with zero hassle. -
Ultrafast 802.11ac Wi-Fi
ZENBOOK UX310 lets you get connected faster and further with the 802.11ac Wi-Fi. And Bluetooth lets you connect your favorite devices with less impact on battery life. ZENBOOK UX310 gives you the freedom to do whatever you need to do, wherever you want to do it! -
Outstandingly comfortable backlit keyboard
ZENBOOK UX310's full-size backlit keyboard is sturdily constructed in a single piece for a superb typing experience. It's a masterpiece of ergonomics, with an optimized key travel for a comfortable feel. The gentle backlight ensures easy use in low-light conditions.
- ASUS ZenBook UX310UA FC999R - 13.3" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 13.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 3-cell
- Quartz grey spin (LCD cover), quartz grey (top)
- 32.3 cm x 22.3 cm x 1.9 cm
- 1.4 kg
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD 2.5" SATA 6Gb/s
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 72% NTSC
- ASUS Splendid Video Intelligence Technology, anti-glare, WideView, Vivid Color
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Sound
- Harman/kardon stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster
Input
- Keyboard, touchpad
Communications
- Wireless
- Technology
- 3-cell Lithium Ion
- Capacity
- 48 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- USB-C 3.1 Gen 1 , 2 x USB 2.0 , USB 3.1 Gen 1 , Headphone/microphone combo jack , HDMI
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card)
- System password, Intel Anti-Theft Technology (iAT)
- Included Accessories
- Power adapter, sleeve
- 1.4 kg
Sustainability Information
- TCO Certified
