Take your creativity and productivity to the next level with the groundbreaking ASUS ZenBook Pro Duo. Designed to give you the ultimate edge in workflow efficiency, the powerful RTX Studio Laptop features a full-width 4K ASUS ScreenPad Plus that works seamlessly with the main 4K UHD OLED display. It's never been this easy to harness your full creative power.
ScreenPad Plus: experience ultimate productivity
ASUS ScreenPad Plus gives you on-the-go computing like you've never experienced before. It's a full-width 4K secondary touchscreen that works seamlessly with the main 15.6-inch 4K UHD OLED touchscreen, giving you endless ways to optimize and personalize your workflow. A series of handy built-in apps help boost your productivity. Quick Key allows one-tap automation of complex keyboard sequences, and Handwriting lets you input text intuitively. There are also useful quick controls such as App Switcher, ViewMax and Task Swap for intuitive interactions between the main display and ScreenPad Plus. -
4K UHD OLED with ultra-slim bezels
The 4K UHD NanoEdge OLED HDR display on ZenBook Pro Duo is truly amazing, with a four-sided frameless design featuring ultra-slim bezels. The brilliant OLED touchscreen delivers ultra-vivid colors and deep blacks, with a cinema-grade 100% DCI-P3 color gamut making it a superb all-rounder for professional work and entertainment. The barely-there bezels increase the screen-to-body ratio to a near-borderless 89%, giving you more screen, and less distraction! -
NumberPad: ultimate numeric keypad solution
ZenBook Pro Duo features the latest version of the ASUS NumberPad, an LED-illuminated numeric keypad integrated into the touchpad. Tap on the top-right NumberPad icon for one second to switch the function on and off, and tap on the top-left icon to choose one of two brightness levels. Even when the NumberPad is activated, the touchpad can be used for cursor control thanks to its intelligent software. -
Hands-free login with face unlock
Enjoy hands-free login on your laptop, using the infrared camera with Windows Hello to login with just a glance - even in the dark! -
Ultra-fast connectivity
ZenBook Pro Duo is built for creative professionals, so there's no compromise on connectivity. A full set of high-performance I/O ports - including the Thunderbolt 3 USB-C port - give you dongle-free connectivity whatever you're doing, wherever you are. The Intel Wi-Fi 6 with Gig+ (802.11ax) takes wireless speeds to the next level, for supersmooth connections to the world. -
Audio tuned by Harman Kardon
The ASUS Golden Ear team worked with renowned home and automotive audio experts Harman Kardon to ensure the best audio experience. A tailored mix of superior hardware - including smart amplifier technology that delivers louder sound with no distortion - and finely tuned software gives you sound like no other laptop. -
Military-grade toughness and build quality
ZenBook Pro Duo meets the ultra-demanding MIL-STD 810G military standard for reliability and durability, undergoing a punishing test regime that includes extended tests for operation in harsh environments including extreme altitudes, temperatures and humidity. It has also passed ASUS internal laptop tests that far exceed the standards set by the industry.
- ASUS ZenBook Pro Duo UX581LV H2024T - 15.6" - Intel Core i9 - 10980HK - 32 GB RAM - 1 TB SSD
- Product Type
- Notebook
- Operating System
- Windows 10 Home
- Processor
- Intel Core i9 (10th Gen) - 10980HK / 2.4 GHz (5.3 GHz) / 16 MB Cache
- Memory
- 32 GB DDR4 (provided memory is soldered)
- Storage
- 1 TB SSD - NVMe
- Display
- 15.6" OLED touchscreen 3840 x 2160 / Ultra HD 4K
- Graphics
- NVIDIA GeForce RTX 2060
- Video Memory
- 6 GB GDDR6 SDRAM
- Input Device
- Stylus, NumberPad, ScreenPad Plus
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax
- Battery
- 8-cell
- Security
- Firmware Trusted Platform Module (TPM) Security Chip
- Celestial blue
- 35.9 cm x 24.6 cm x 2.4 cm
- 2.5 kg
- SAR
- 0.285 W/kg (body), 0.285 W/kg (limb)
- Product Type
- Notebook
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Intel Core i9 (10th Gen) 10980HK / 2.4 GHz
- Max Turbo Speed
- 5.3 GHz
- Number of Cores
- 8-core
- Cache
- 16 MB
- 64-bit Computing
- Chipset
- Intel HM470
- Intel Turbo Boost Max Technology 3.0
- RAM
- 32 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2933 MHz
Storage
- Main Storage
- 1 TB SSD M.2 PCIe - NVM Express (NVMe)
Display
- 15.6" OLED
- Touchscreen
- Resolution
- 3840 x 2160 (Ultra HD 4K)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 100% DCI-P3
- Glare, Pantone Validated
Audio & Video
- Graphics Processor
- Video Memory
- 6 GB GDDR6 SDRAM
- Camera
- Yes - 720p
- Camera Features
- IR camera, Windows Hello
- Sound
- Harman/kardon stereo speakers, array microphone
Input
- Keyboard, stylus, NumberPad, ScreenPad Plus
- Numeric Keypad
- Chiclet keyboard, 14" 4K UHD (3840 x 1100) touch display
Communications
- Wireless
- Dual stream (2x2)
- Technology
- 8-cell Lithium Ion
- Capacity
- 71 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 230 Watt, 19.5 V, 11.8 A
Connections & Expansion
- USB-C (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , 2 x USB 3.2 Gen 2 , Headphone/microphone combo jack , HDMI
- Celestial blue
- Case Material
- Aluminum
- Security
- Included Accessories
- Stylus, power adapter, stand, wrist rest
- MIL-STD 810G
- SAR Value
- 2.5 kg
