Asus Zenbook i7-7500U 8GB 256GB SSD 14" Windows 10 - Royal Blue
Quicklinx: D978WS00 Mfr#: UX430UA-GV232T
  • Core i7
  • IEEE 802.11n
With the elegant and sophisticated ZenBook UX430 you don't have to make the difficult choice between portability and screen size - it delivers both. The slim and lightweight design, iconic ZenBook styling, and high-performance components make the ZenBook UX430 a portable powerhouse you won't want to leave behind, wherever you go. Take more with you, in less space.
  • See more, do more
    When it comes to getting things done, everyone agrees that a bigger display is a better display, because it makes multitasking easier and entertainment more immersive. That's why the ZenBook UX430 has a big screen. With a reduced bezel, it has a stunning display into a svelte chassis. To maximize your viewing comfort, the display also has a matte anti-glare coating that reduces annoying reflections.
  • Viewing perfection
    The ZenBook series has superb display quality, and the ZenBook UX430 is no exception. Its anti-glare display has an ultra-wide color gamut, which means it can display more accurate and more vivid colors. It also uses wide-view technology to ensure that contrast and color reproduction are not degraded at wider viewing angles, making it perfect for collaboration and screen sharing.
  • Timeless elegance
    Elegance, sophistication and style are the hallmarks of the ZenBook series. The exquisite ZenBook UX430 continues that tradition, combining precision craftsmanship and premium materials to give you a laptop that stands out from the crowd. The Zen-inspired, concentric-circle design is enhanced with a stunning crystal-like coating that's created using an advanced technique known as nano-imprinting lithography.
  • All-day battery
    Designed for non-stop, on-the-go lifestyles, the ZenBook UX430 offers the freedom of all-day battery life. A special battery gives the ZenBook UX430 sevral hours of autonomy.
  • Every connection you need
    The ZenBook UX430 is equipped with the reversible USB Type-C port that offers an any-way-up design to make connecting devices as easy as possible. It also delivers fast data transfer speeds. Along with the USB-C port, there's a USB 3.1 and an SD card slot - so you can easily connect all your peripherals, displays and projectors with zero hassle.
  • Sound that will amaze you
    A tailored mix of superior hardware - including smart amplifier technology that delivers louder sound with no distortion - and cleverly designed software ensure that the ZenBook UX430 gives you an incredible audio experience.
ASUS Zenbook UX430UA GV232T - 14" - Intel Core i7 - 7500U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
3-cell - up to 9 hours
Security
Firmware Trusted Platform Module (TPM) Security Chip, fingerprint reader
Royal blue
32.4 cm x 22.5 cm x 1.59 cm
1.25 kg
0.603 W/kg (body) , 0.603 W/kg (limb)
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (7th Gen) 7500U / 2.7 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2133 MHz
Storage
Main Storage
256 GB SSD SATA 6Gb/s
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Colour Gamut
72% NTSC
ASUS Splendid Video Intelligence Technology, anti-glare, WideView, ASUS EyeCare Technology
Audio & Video
Graphics Processor
Camera
Yes - HD
Sound
Harman/kardon stereo speakers, microphone
Audio Features
Output: ASUS SonicMaster
Input
Keyboard, touchpad
Communications
Wireless
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
3-cell
50 Wh
Run Time
Up to 9 hours
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Interfaces Details
USB 2.0 , Micro-HDMI , USB 3.0 , Headphone/microphone combo jack , USB-C 3.1 Gen 1 , LAN (on supplied adapter)
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Royal blue
Security
System password, hard drive password
Power adapter, sleeve, USB 3.0 to Gigabit Ethernet adapter
Micro-HDMI-HDMI cable
SAR Value
0.603 W/kg (body), 0.603 W/kg (limb)
1.25 kg
Sustainability Information
TCO Certified
