Asus Zenbook i5-10210U 8GB 256GB 14" Windows 10
Quicklinx: FHMSWS00 Mfr#: UX434FAC-AI246T
Display Size: 14in
Processor Model: I5-10210U
Operating System: Windows 10 Home
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
Hurry, only 2 left in stock!
£950.59 ex VAT
£1,140.70 inc VAT
Marketing description is not available.
  • Compact design
    ZenBook 14 heralds an era of portable design, with an ultra-compact, ultra-light chassis. Featuring the 4-sided NanoEdge display, the ZenBook 14 is extremely sleek.
  • Unbounded beauty
    Designed to give you more screen area in less physical space, the frameless four-sided NanoEdge design of ZenBook 14 is simply breathtaking: it makes any visuals more immersive, with less distraction for your eyes.
  • Spectacular visuals
    Creativity demands a great screen, so ZenBook 14 has a crisp, clear, high-resolution display that makes any visuals look their best, with wide viewing angles and vivid, accurate colors.
  • Designed with you in mind
    With any ZenBook, your comfort is a high priority ZenBook 14 goes the extra mile with its exclusive hinge, an engineering masterpiece designed to automatically tilt the keyboard to a comfortable typing position. But that's not all: the carefully calculated tilt improves cooling and audio performance, too.
  • Mobility without bounds
    As a mobile professional, you need to stay connected. ZenBook 14 is equipped with Wi-Fi, so you can enjoy fast downloads and smooth streaming with greater range and more stable network connections.
  • All-day battery for non-stop lifestyles
    ZenBook 14 is powered by a high-capacity battery that won't let you down, however long and demanding your working day is. Extended journeys or day-long meetings are no problem for ZenBook 14, even when power outlets are in short supply.
ASUS ZenBook 14 UX434FAC-AI246T - 14" - Core i5 10210U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Windows 10 Home
Intel Core i5 (10th Gen) 10210U / 1.6 GHz (4.2 GHz) / 6 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
14" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics
Input Device
ScreenPad 2.0
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11ax
3-cell
Security
Trusted Platform Module (TPM) Security Chip
Royal blue
31.9 cm x 19.9 cm x 1.69 cm
1.26 kg
Limited warranty - 1 year
Notebook
Operating System
Windows 10 Home
Processor / Chipset
CPU
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
2133 MHz
Storage
Main Storage
256 GB SSD - (M.2) PCIe
Display
14" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Bezel Type
Flat front
ASUS Splendid Video Intelligence Technology, glare, 72% NTSC colour gamut, 178° horizontal and vertical viewing angle, NanoEdge display
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Camera Features
IR camera
Sound
Harman/kardon stereo speakers, microphone
Audio Features
ASUS Bang & Olufsen ICEpower, Smart Amplification technology
Input
Keyboard, ScreenPad 2.0
Keyboard Backlight
Chiclet keyboard
Communications
Wireless
3-cell lithium polymer
50 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 3.42 A
Connections & Expansion
Headphone/microphone combo jack , USB-C 3.1 Gen 2 , USB 3.1 Gen 2 , HDMI , USB 2.0
Memory Card Reader
Yes (microSD)
Royal blue
Security
System password, ErgoLift
Theft/Intrusion Protection
Cable lock
Power adapter
1.26 kg
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics
Hard Drive Type: SSD
Brand: Asus
Price Range Ex VAT: 750 - 1000
