The ZenBook UX410 brings you elegance, sophistication and superb performance in a gorgeously slim and light design. Crafted from solid aluminum and featuring a spun-metal finish, the ZenBook UX410 is thin. And its light weight means taking it with you is never a burden, and using it is always a pleasure with its crisp, clear display.
Sleek and elegant
Using solid aluminum alloy keeps the weight down, but it takes precisely controlled manufacturing steps to craft it into its sleek shape. The spun-metal finish, adorns the lid, with a tough and durable brushed metal finish adorning the rest of the chassis. -
Incredible performance
Superb mobile performance is the hallmark of the ZenBook UX410. This performance is delivered by a fast processor, with plenty of RAM for ultra-smooth video. True professionals demand great technology, and the reversible USB Type C port gives you high-speed access to high-performance peripherals. With the HDMI port, you can connect to monitors, TVs or projectors with no hassle. Effortless multitasking, smooth video playback, and super-fast application launches - the ZenBook UX410 is always ready when you are. -
Protect your eyes with ASUS Eye Care
Too much exposure to the blue light emitted by LCD displays is thought to affect eye health, and it can also cause fatigue during long viewing sessions. ASUS Eye Care reduces the emissions of blue light, so that your eyes are always protected. -
Great connectivity
The ZenBook UX410 is equipped with the reversible USB Type C port with its any-way-up design, that makes connecting devices so much easier. It also delivers fast data transfer speeds. In addition, the ZenBook UX410 has USB 3.0 ports, and an SD card slot, so you can easily connect your peripherals, displays and projectors with zero hassle. -
Comfortable backlit keyboard
The ZenBook UX410's full-size backlit keyboard is sturdily constructed in a single piece for a superb typing experience. It's a masterpiece of ergonomics, with an optimized key travel for a comfortable feel. The gentle backlight ensures easy use in low-light conditions. -
Designed to sound incredible
ASUS SonicMaster technology delivers incredible sound. A tailored mix of superior hardware ensures, that the ZenBook UX410 gives you an amazing sound experience.
- ASUS ZenBook UX410UA GV158T - 14" - Intel Core i3 - 7100U - 4 GB RAM - 128 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i3 (7th Gen) - 7100U / 2.4 GHz / 3 MB Cache
- Memory
- 4 GB DDR4 (provided memory is soldered)
- Storage
- 128 GB SSD
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Ethernet
- Battery
- 3-cell
- Quartz grey spin (LCD cover), quartz grey (top)
- 32.3 cm x 22.3 cm x 1.895 cm
- 1.4 kg
- Specific Absorption Rate (SAR)
- 0.389 W/kg (body) , 0.389 W/kg (limb)
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i3 (7th Gen) 7100U / 2.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD M.2 SATA 6Gb/s
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 72% NTSC
- ASUS Splendid Video Intelligence Technology, anti-glare, WideView
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster
Input
- Keyboard, touchpad
Communications
- Wireless
- Network Interface
- Ethernet
- Technology
- 3-cell Lithium Ion
- Capacity
- 48 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- 2 x USB 2.0 , HDMI , USB 3.0 , Headphone/microphone combo jack , USB-C 3.1 Gen 1 , LAN (on supplied adapter) , VGA (on supplied cable)
- Memory Card Reader
- Yes (SD Card, MultiMediaCard)
- System password, Intel Anti-Theft Technology (iAT)
- Theft/Intrusion Protection
- Included Accessories
- Power adapter, sleeve, USB 3.0 to Ethernet adapter
- Cables Included
- HDMI-VGA cable
- SAR Value
- 0.389 W/kg (body), 0.389 W/kg (limb)
- 1.4 kg
Sustainability Information
- TCO Certified
