ZenBook 3 Deluxe achieves the almost-impossible, featuring a gorgeous 14-in display in an elegant and compact chassis that's no bigger than many 13-inch laptops. It's an unrivaled combination of power and beauty, giving you the perfect balance between portability and productivity. ZenBook 3 Deluxe has everything you need for superb on-the-go performance, including a powerful processor, three USB Type-C (USB-C) ports - two of which feature Thunderbolt 3 - and a powerful quad-speaker audio system. ZenBook 3 Deluxe takes ZenBook 3 to the next level - for the ultimate prestige and performance.
Crafted to perfection
ZenBook 3 Deluxe has a very simple design philosophy: never compromise. It's a masterpiece of craftsmanship, with a beauty that reflects a painstaking attention to detail. The perfect curves of the all-aluminum chassis are carved from a single block of metal. A complex two-phase anodizing process is then used to create the elegant golden diamond-cut edges and unique golden ASUS lid logo. The result is a breathtakingly exquisite design that offers the perfect combination of beauty, mobility, performance and productivity. -
The 13-inch laptop with a 14-inch display
The chassis of ZenBook 3 Deluxe is the size of many 13-inch laptops - yet it features an extra-large 14-inch display. ZenBook 3 Deluxe is constructed from premium, aerospace-grade aluminum alloy. This grade of allow is stronger than standard alloy, allowing the ZenBook 3 Deluxe to have an amazingly thin profile. Its 14-inch display is covered with a layer of Corning Gorilla Glass 5. This super-tough material is stronger and more scratch-resistant. -
Ultra-realistic visuals
To deliver the ultimate visual experiences, ZenBook 3 Deluxe harnesses the power of exclusive ASUS display technologies, with optimized hardware and software components combined to deliver excellent imagery. The wide 100% sRGB color gamut and TV-grade 1000:1 contrast ratio ensure more-vivid, more-lifelike colors, and ASUS Splendid technology fine-tunes display parameters to ensure superb color accuracy while also providing automatic optimization for any kind of image. ASUS Tru2life Video is a remarkable real-time video enhancement technology that optimizes the appearance of every pixel in every video frame, delivering awesome contrast improvement and pin-point sharpness. -
Thunderbolt 3 for unlimited possibilities
ZenBook 3 Deluxe has no less than three USB-C ports, and two of them incorporate the Thunderbolt 3 technology for versatile, ultra-fast connections. Thunderbolt 3 supports data transfers at up to 40 Gbps, which is twice the bandwidth of Thunderbolt 2 and eight times faster than USB 3.0. The Thunderbolt 3-enabled USB-C ports also support power delivery. Additionally, Thunderbolt 3 delivers enhanced graphics options to improve productivity or gaming performance, with support for dual 4K UHD external displays. -
Mobility without bounds
ZenBook 3 Deluxe is fully equipped to give you amazing connection - anywhere. It features the power-efficient Bluetooth 4.1 and dual-band 802.11ac Wi-Fi, which is more reliable and three times faster than the 802.11n. -
No-compromise productivity
With ZenBook 3 Deluxe, the keyboard was engineered into the design from the start. Its full-size backlit keyboard has impressive key travel, making typing more comfortable and more accurate. ZenBook 3 Deluxe also includes a precision touchpad that's cleverly engineered for maximum comfort and accuracy, with a glass covering for smooth control, and incorporating palm-rejection technology, multi-touch gestures and handwriting support. -
Sound that will amaze you
ZenBook 3 Deluxe has an array of four separate high-quality speakers designed to deliver true surround-sound that envelops you with cinema-quality audio. A special four-channel smart amplifier ensures maximum volume with zero distortion, for powerful, clear sound.
- ASUS ZenBook 3 Deluxe UX490UA BE012T - 14" - Intel Core i7 - 7500U - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache
- Memory
- 16 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB SSD
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac
- Battery
- 4-cell - up to 9 hours
- Royal blue
- 32.9 cm x 21 cm x 1.29 cm
- 1.1 kg
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (7th Gen) 7500U / 2.7 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 512 GB SSD
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Colour Gamut
- 100% sRGB, 72% NTSC
- Ultra Slim Design, ASUS Splendid Video Intelligence Technology, WideView, 178° horizontal and vertical viewing angle, Corning Gorilla glass 5
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - VGA
- Sound
- Harman/kardon quad speakers, microphone
- Audio Features
- Output: ASUS SonicMaster Premium, ASUS AudioWizard
Input
- Keyboard, touchpad
- ASUS Smart Gesture technology
Communications
- Wireless
- Technology
- 4-cell lithium polymer
- Capacity
- 46 Wh
- Run Time
- Up to 9 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V
Connections & Expansion
- Interfaces Details
- Headphone output , USB-C 3.1 Gen 1 , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3)
- Royal blue
- Case Material
- Aluminum
- Included Accessories
- Power adapter
- 1.1 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
