Asus Zenbook 14" Core i7-7500U 8GB 256GB SSD Windows 10 - Quartz Grey
Quicklinx: F8ZLWS00 Mfr#: UX410UA-GV183T
  • Core i7
  • IEEE 802.11n
The all-new ZenBook UX410 brings you elegance, sophistication and superb performance in a gorgeously slim and light design. Crafted from solid aluminum and featuring our iconic spun-metal Zen-inspired finish, ZenBook UX410 is a mere 18.95mm thin. And its travel-friendly weight of just 1.4kg means taking it with you is never a burden, and using it is always a pleasure with its crisp, clear 14-inch wide viewing angle display and 6mm slim bezel. ZenBook UX410 makes everything easier, in style.
Ultra Sleek. Ultra Elegant
The ZenBook Series practically invented thin and light, and ZenBook UX410 continues that proud heritage, featuring a timelessly elegant all-new design with a profile that's just 18.95mm thin. Using solid aluminum alloy keeps the weight down to just 1.4kg, but it takes dozens of precisely-controlled manufacturing steps to craft it into its sleek shape. Our unique spun-metal finish, with its Zen-inspired concentric circles, adorns the lid, with a tough and durable brushed-metal finish adorning the rest of the chassis. Finally, we anodize ZenBook UX410 in one of two nature-inspired shades: Quartz Grey or Rose Gold.
Incredible Performance
Superb mobile performance is the hallmark of ZenBook, and in ZenBook UX410 this is delivered by an Intel® Core™ i7 Processor, 8GB RAM. The latest dual-band 802.11ac Wi-Fi provides super-fast speeds, and Bluetooth® 4.1 connects you easily to your gadgets. True professionals demand the latest technology, and the revolutionary, reversible USB Type-C port gives you high-speed access to the latest high-performance peripherals. With the HDMI port, you can connect to monitors, TVs or projectors with no hassle. Effortless multitasking, smooth video playback, and super-fast application launches — ZenBook UX410 is always ready when you are. It's supremely energy-efficient too, meaning fewer trips to the power socket!
  • Ultra-sleek and ultra-elegant
    The ZenBook Series practically invented thin and light, and ZenBook UX410 continues that proud heritage, featuring a timelessly elegant design with a thin profile. Using solid aluminum alloy keeps the weight down to just 1.4 kg, but it takes dozens of precisely controlled manufacturing steps to craft it into its sleek shape.
  • Big and clear display
    With ZenBook UX410, ASUS has achieved the impossible: fitting a stunning 14-inch up to Full HD display into a laptop that's no bigger than most 13-inch models. The secret is the ultra-slim bezel, which not only allows us to fit a larger screen, but also gives you distraction-free viewing whether you're reading text, viewing photos or watching videos. The amazing resolution makes photo or video editing so much easier, and the incredible pixel density of 276 pixels per inch makes every tiny detail pin-sharp and crystal-clear.
  • ASUS Splendid: superbly optimized color
    To ensure only the very best images, ZenBook UX410 incorporates ASUS Splendid technology to give you richer, deeper and more accurate colors. ASUS Splendid has four one-click preset modes: Normal mode, Eye Care mode, Vivid mode and Manual mode. Normal mode gives you the factory-optimized settings, Eye Care mode reduces blue light levels for comfortable viewing, and Vivid mode cleverly adjusts the display settings to give images a really vibrant and vivid appearance, without making the colors look artificial. Manual mode gives you control over the color temperature setting, so you can adjust the display to suit your own needs and preferences.
  • Ultra connectivity
    ZenBook UX410 is equipped with the reversible USB Type-C port with its any-way-up design that makes connecting devices so much easier. It also delivers data transfer speeds up to 10 times faster than older USB 2.0 connections! In addition, ZenBook UX410 has a USB 3.0 port, an HDMI port and an SD card slot so you can easily connect your current peripherals, displays and projectors with zero hassle.
  • Outstandingly comfortable backlit keyboard
    ZenBook UX410's full-size backlit keyboard is sturdily constructed in a single piece for a superb typing experience. It's a masterpiece of ergonomics, with an optimized 1.6mm key travel for a comfortable feel. The gentle backlight ensures easy use in low-light conditions.
  • ASUS SonicMaster: designed to sound incredible
    Incredible sound has always been a feature of the ZenBook family. Co-developed by the ASUS Golden Ear team and Harman Kardon, ASUS SonicMaster technology delivers incredible sound. A tailored mix of superior hardware and cleverly designed software ensure that ZenBook UX410 gives you the ultimate sound experience.
ASUS ZenBook UX410UA GV183T - 14" - Intel Core i7 - 7500U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i7 (7th Gen) - 7500U / 2.7 GHz (3.5 GHz) / 4 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Ethernet
3-cell
Quartz grey
32.3 cm x 22.3 cm x 1.895 cm
1.4 kg
SAR
0.389 W/kg (body), 0.389 W/kg (limb)
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (7th Gen) 7500U / 2.7 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0, Intel Anti-Theft Technology
RAM
8 GB (provided memory is soldered)
Max RAM Supported
16 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Colour Gamut
72% NTSC
ASUS Splendid Video Intelligence Technology, anti-glare, ASUS EyeCare Technology, 178° horizontal and vertical viewing angle, NanoEdge display
Audio & Video
Graphics Processor
Camera
Yes - HD
Sound
Stereo speakers, microphone
Audio Features
Output: ASUS SonicMaster
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Network Interface
Ethernet
3-cell Lithium Ion
48 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
2 x USB 2.0 , HDMI , USB 3.0 , Headphone/microphone combo jack , USB-C 3.1 Gen 1 , LAN (on supplied adapter) , VGA (on supplied cable)
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card)
Quartz grey
System password
Theft/Intrusion Protection
Power adapter, sleeve, USB to Ethernet adapter
HDMI-VGA cable
SAR Value
1.4 kg
