Creativity. Style. Innovation. These are the qualities that define the elegant ZenBook 14. Everything in this super-compact masterpiece is designed to give you the freedom to discover your creative vision, including the stunning slim-bezel NanoEdge display with its 86% screen-to-body ratio. You'll appreciate not only the tremendous power within and the thoughtful attention to detail but also the timeless beauty of the design.
NanoEdge display
Designed to give you more screen area in less physical space, the NanoEdge design has slimmer bezels on all four sides to make any visuals more immersive, with less distraction for your eyes. It also features wide-view technology for clear images even when viewed from extreme angles. And thanks to this super-compact display, ZenBook 14 has a footprint that's as small as many 13-inch laptops - so you can explore your creative vision anywhere! -
ErgoLift hinge
With any ZenBook, your comfort is one of ASUS's top priorities. ZenBook 14 goes the extra mile with its exclusive ErgoLift hinge, an engineering masterpiece designed to automatically tilt the keyboard to the most comfortable typing position. But that's not all: the carefully calculated tilt improves cooling and audio performance, too. -
Ultimate audio experience
To create the astounding quad-speaker sound system in ZenBook 14, the ASUS Golden Ear team worked with renowned home and automotive audio experts Harmon Kardon. Two bass speakers and two high-frequency speakers deliver smooth, clear and powerful full-range sound, while smart amplifier technology prevents distortion and speaker damage at high volumes. Together with ASUS SonicMaster technology - a combination of hardware and software fine-tuning - the results are truly astonishing. ZenBook 14 brings you the ultimate audio experience! -
No-compromise productivity
For easy productivity on the go, ZenBook 14 is equipped with backlit keyboard that delivers a superb typing experience. It's a masterpiece of ergonomics, with just the right amount of key travel. -
Mobility without bounds
A comprehensive set of high-performance I/O ports gives ZenBook 14 the ultimate, hassle-free connectivity for versatile flexibility whether you're in the office or on the road. And the integrated gigabit-class Wi-Fi let you enjoy ultrafast downloads and smooth streaming with greater range and more stable network connections than ever before. -
All-day battery for non-stop lifestyles
ZenBook 14 is powered by a high-capacity battery that won't let you down, however long and demanding your working day is. Extended journeys or day-long meetings are no problem for ZenBook 14, even when power outlets are in short supply! -
Ultra-tough: military-grade durability
ZenBook 14 meets the ultra-demanding MIL-STD-810G military standard for reliability and durability, undergoing a punishing test regime that includes extended tests for operation in harsh environments including extreme altitudes, temperatures and humidity.
- ASUS ZenBook 14 UX431FA-AN001T - 14" - Intel Core i5 - 8265U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i5 (8th Gen) - 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD - NVMe
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 2-cell
- Security
- Firmware Trusted Platform Module (TPM) Security Chip, fingerprint reader
- Utopia blue
- 32.4 cm x 21.2 cm x 1.59 cm
- 1.45 kg
- SAR
- 0.049 W/kg (limb), 0.049 W/kg (body)
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 72% NTSC
- ASUS Splendid Video Intelligence Technology, glare, 178° horizontal and vertical viewing angle
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Sound
- Harman/kardon stereo speakers, array microphone
- Audio Features
- Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower
Input
- Keyboard, touchpad
- ASUS Smart Gesture technology
Communications
- Wireless
- Technology
- 2-cell Lithium Ion
- Capacity
- 47 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- Headphone/microphone combo jack , USB-C 3.1 Gen 2 , USB 3.1 Gen 1 , HDMI , USB 2.0
- Memory Card Reader
- Yes (microSD)
- Utopia blue
- Security
- System password, hard drive password
- Included Accessories
- Power adapter
- SAR Value
- 1.45 kg
