The difference between defeat and victory can be measured in milliseconds. That's why we've equipped Z97-PRO GAMER with networking technology that puts your frags first!
The Intel Gigabit Ethernet means faster, smoother gaming - always. Intel's LAN has the serious double advantage of communicating directly with Intel CPUs and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay!
ASUS Z97-PRO GAMER explodes the myth that dedicated sound cards are always better, with integrated SupremeFX technology that achieves near-lossless audio quality with a remarkable signal-to-noise ratio (SNR) of 115dB -- meaning you hear every sound detail. And with exclusive Sonic Radar technology pinpointing the precise direction of in-game sounds you even get a leg up in the game!
Most powerful ASUS Gamer-series ATX-board with SupremeFX, LANGuard, M.2 & SATA Express and highly-durable components.
- LGA1150 socket for the 4th, New 4th & 5th Generation Intel® Core™ i7/ Core™ i5 / Core™ i3, Pentium®, and Celeron® processors
- Dual DDR3 3200(O.C.)support
- SupremeFX - Flawless audio that makes you part of the game
- Intel Gigabit Ethernet, LANGuard & GameFirst II - Networking that just goes faster
- Sonic Radar ll - Scan and detect to dominate
- M.2 & SATA Express - Top-speed transfers for faster gaming
- Gamer's Guardian - for real-world protection
X-faster UDP game-data performance
ASUS engineers used IxChariot, an independent network-assessment test tool, to determine just how much quicker Intel Gigabit Ethernet deals with the UDP data packets that are vital for responsive gaming. The results are in - and with Z97-PRO GAMER your game-data packets flow up to two times (2X) faster! -
LANGuard - RJ45 reinvented
Z97-PRO GAMER has the reinvented LAN port. Advanced signal-coupling technology and premium surface-mounted capacitors improve throughput, while surge-protected and electrostatically-guarded components (ESD Guards) protect your motherboard from lightning strikes and static electricity! -
GameFirst II
GameFirst II with cFosSpeed traffic-shaping technology adds even more lag-reducing support, with an EZ Mode that lets you lower lag with no expert knowledge - by up to eight times (8X)! If you're a tweaker, use Advanced Mode for hardcore controls. -
SupremeFX
SupremeFX is an exclusive ASUS technology that's designed for one purpose - to deliver audio that's in a class of its own. -
Red-line shielding
Horizontally separates SupremeFX audio components from the rest of the motherboard, effectively eliminating interference to ensure flawless sound quality. -
300O-headphone amplifier
Z97-PRO GAMER drives some of the very best headphones available - up to 300O load impedance. Z97-PRO GAMER assures you great compatibility and more impactful output than standard onboard audio hardware. You demand superb effects and superior surround sound for truly immersive gaming experiences, and Z97-PRO GAMER delivers! -
EMI cover
A carefully-engineered protective shield isolates the advanced audio chipset from electromagnetic interference (EMI), preserving the integrity of the audio signals. -
Premium ELNA audio capacitors
They are added to the mix to deliver a warmer, natural sound to complete the audio experience. -
Sonic Radar II
Designed for first-person shooters (FPS), Sonic Radar II displays a stealthy overlay that shows what opponents and teammates are up to. See the precise direction and origin of in-game sounds such as gunshots, footsteps and call-outs, and practice your enemy-pinpointing skills - and exclusive Audio Enhancement further improves in-game sound for superb hearing awareness. -
Evolve your storage speed with SATA Express
SATA Express provides up to 10Gbit/s data-transfer speeds from two PCI Express 2.0 lanes, so you're all set for the next generation of super-fast SSDs. Existing SSDs consume up to 550MB/s of bandwidth, which is close to the saturation point for SATA 6Gbit/s connections - but Z97-PRO GAMER's SATA Express interface smashes this through this speed barrier. Backwardly compatible with up to two SATA drives, SATA Express is the next-generation connectivity standard that ensures you and your game won't get left behind. -
Faster gaming with M.2
Z97-PRO GAMER includes an M.2 socket with two native PCI Express 2.0 lanes for data-transfer speeds of up to 10 Gbit/s. This is the perfect choice for an operating system drive to make every gaming experience faster and more fun. Z97-PRO GAMER also supports Intel Rapid Storage Technology to ensure even faster access to data, refresh applications automatically and awake from sleep in just seconds! -
ESD Guards
With ASUS ESD Guards your Z97-PRO GAMER is actively protected against sudden electrostatic discharge (ESD), meaning the components will last much longer - and you get protection that's up to twice as resilient as industry standards!
- ASUS Z97-PRO GAMER - motherboard - ATX - LGA1150 Socket - Z97
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z97 Express
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 4 x SATA-600 (RAID), 1 x SATA Express port, 1 x M.2
- USB / FireWire Ports
- 4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
- Max Allocated RAM Size
- 512 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z97 Express
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 2133 MHz (O.C.), 2000 MHz (O.C.), 1866 MHz (O.C.), 3000 MHz (O.C.), 3100 MHz (O.C.), 3200 MHz (O.C.), 2250 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 512 MB
Audio
- Audio Codec
- SupremeFX
- High Definition Audio
LAN
- Network Controller
- Intel I218V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe x1 , 2 x PCI
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Smart Response Technology
- 1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x HDMI , 4 x USB 3.0 , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 1 x DVI-D
- Internal Interfaces
- 6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS EZ Flash 2, UEFI BIOS, DMI 2.7 support, ACPI 5.0 support, SMBIOS 2.8 support
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- Jack retasking, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASUS TurboV, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Intel Clear Video HD Technology, Intel Smart Response Technology, USB 3.0 Boost, SupremeFX Shielding technology, AMD Quad CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 3, Dual Intelligent Processors 5, LANGuard, Sonic Radar II
- Included Accessories
- I/O back plate
- Cables Included
- 4 x Serial ATA cable , 1 x SLI bridge
- Software Included
- Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, ASUS HomeCloud, ASUS Turbo App, Antivirus (OEM version)
- Plug and Play, ACPI 5.0
- 30.5 cm
- 24.4 cm
