Asus Z240ICGT-GF011X 23.8" Touch, i7-6700T, GTX960m 2GB, 16GB Win
Quicklinx: BWBFWS00 Mfr#: Z240ICGT-GF011X
  • Bluetooth 4.0
  • IEEE 802.11n
  • Core i7
  • NVIDIA GeForce GTX 960M
A stunning PC needs suitably stunning visuals, so Zen AiO S is equipped with up to a glorious 1920 x 1080 (Full HD) display that not only shows every minute detail, but also has vividly-lifelike colors and wide 178° viewing angles. No matter how you look at it, the screen of Zen AiO S is a marvel.
The screen on Zen AiO S has a wide color gamut of up to 82% NTSC, 85% Adobe RGB and 100% sRGB. This is simply a technical way of saying that Zen AiO S reproduces more colors, more accurate colors, and colors that are richer and more vivid than a standard display.
Zen AiO S is a precision-crafted masterpiece inspired by the spirit of Zen. It combines the simplicity of pure aluminum with the sophistication of advanced technology to create timeless yet practical beauty for your home. The elegant and incredibly-slim anodized aluminum cover and integral stand are hewn from solid aluminum. Zen AiO S is beautifully-finished in stunning Icicle Gold, enhanced with the iconic and unique spun-metal finish with its Zen-inspired concentric-circle pattern. To reduce distractions to the minimum, a flawless edge-to-edge glass display that blends seamlessly with the bezel to give you an uninterrupted viewing area. It's this attention to the smallest details that set Zen AiO S apart.
Zen AiO S is designed for the ultimate home entertainment, using a total of 6 speakers to deliver rich and clear full-range sound. Each 8-Watt stereo channel uses three powerful speakers located at either side of Zen AiO S, giving fully-realistic stereo separation and a total of 16 Watts of pure, undistorted sound for an amazingly lifelike entertainment experience. You won't believe how good Zen AiO S sounds, whether you're watching the latest blockbuster, playing games or relaxing to your favorite tunes.
Zen AiO S is the world's first all-in-one PC to use the next-generation USB 3.1 Gen 2, which delivers blindingly-fast data transfers of up to 10Gbit/s - that's twice as fast as USB 3.0, and over 20-times faster than USB 2.0! With these speeds, even the biggest data transfers take no time at all. Zen AiO S uses the latest Type-C connector for improved ease of use - the connector is reversible, so it can't be inserted the wrong way round! And for maximum connectivity, Zen AiO S also has a full complement of 4 USB 3.0 ports plus a USB 2.0 port.
Zen AiO S is equipped with an amazingly-accurate 3D camera that uses Intel RealSense technology to add futuristic capabilities to your PC. Accurate motion-sensing of people or objects in front of the camera is now possible, making previously-unimagined ways of interacting with your PC a reality. For example, with precise 3D facial recognition, your face can become your login password for a fast, simple and secure way to access your computer. Or you and your family can just have fun interacting with the latest motion-controlled games. The possibilities with Zen AiO S are truly endless!
  • Immerse yourself in detail
  • Richer, more accurate colors
  • A true modern masterpiece
  • Incredible sound, awesome entertainment
  • Ultra-fast USB 3.1 Gen 2 Type-C port
  • 3D camera puts you in control
ASUS Zen AiO Pro Z240ICGT - all-in-one - Core i7 6700T 2.8 GHz - 16 GB - SSD 128 GB, HDD 1 TB - LED 23.8"
Personal computer - all-in-one - ASUS SonicMaster Premium
Intel Core i7 (6th Gen) 6700T / 2.8 GHz (, up to 3.6 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
16 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 128 GB - M.2
Hard Drive (2nd)
HDD 1 TB - SATA 6Gb/s - 5400 rpm
Optical Storage
No optical drive
Card Reader
2 in 1
Monitor
23.8" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
Graphics Controller
Video Memory
2 GB
Camera
Audio Output
Stereo
GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
OS Provided
Windows 10 Home 64-bit Edition
Golden
58.5 cm x 19 cm x 43.4 cm
7.3 kg
Personal computer
Product Form Factor
All-in-one
Golden
Processor / Chipset
CPU
Clock Speed
2.8 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
16 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Slots
2 (Total) / 0 (empty)
Unbuffered
Configuration Features
2 x 8 GB
Hard Drive
SSD - M.2
1 x 128 GB
Hard Drive (2nd)
HDD
Interface Class
Serial ATA
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Card Reader
2 in 1 card reader
Supported Flash Memory Cards
MultiMediaCard, SD Memory Card
Monitor
Monitor Type
LED
Touchscreen
Yes (10-point multi-touch)
Diagonal Size
23.8"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Graphics Controller
Graphics Processor
Video Memory
2 GB
Audio Output
Sound Output Mode
Stereo
Speakers Included
4 x right / left channel , 2 x subwoofer
Camera
Camera
Input Device
Mouse, keyboard
Keyboard
Wireless
Mouse
Wireless
Audio Input
Microphone
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 0 (free) x SO-DIMM 260-pin
4 x USB 3.0 , 1 x USB 2.0 , 2 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 1 x USB-C 3.1
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Power Provided
180 Watt
Operating System / Software
OS Provided
58.5 cm
19 cm
43.4 cm
7.3 kg
BWBF C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
